Truck won't start
Old Aug 2, 2009 | 01:35 PM
429PI IN 75 f-100's Avatar
429PI IN 75 f-100
Cool Truck won't start
The other die i turned my truck off for about ten minutes and then i went to start it and it would crank good but not start and the wait to start light stayed on and my water pump started leaking at the same time. Hoping it is just the CPS is there any way of testing these or could be my HPOP the truck is a 95 with about 218,000 on the original HPOP the truck has an edge programmer. Really need help to get truck up and running soon Thanks for any help
Old Aug 2, 2009 | 01:59 PM
IDMooseMan's Avatar
IDMooseMan
There's no real test to see if the CPS is good or bad. Is it throwing a code?
Check the HPOP to make sure it has the proper amount of oil. If it's low, the injectors won't fire.
To eliminate the programmer as a potential problem, remove it and try to restart the truck. If the truck starts after removing, the programmer is most likely the problem.
The water pump leak is a completely different issue you'll need to deal with.
Welcome to
Old Aug 2, 2009 | 03:35 PM
Copedawg's Avatar
Copedawg
From what I understand, the tach won't bounce up and down when cranking if the CPS is bad.
barko4
Feb 16, 2015 09:47 PM
Dean88
Oct 30, 2011 09:23 PM
takenreality
Sep 22, 2011 03:45 AM
crapr6
30
Jan 29, 2008 07:07 PM
357fhp
Nov 12, 2006 11:59 AM
