I'm thinking about buying a 2004+ F-150 and I have a question for you guys that work on your own. How hard is it working on the engine when half of it is under the dash?
yeah its not really under the dash at all, having just bought my 04 5.4, the problem is everything is electronic which i am not use too, so parts are expensive and not worth working on yourself in my opinion, if you find the right ford dealer to work on your truck its not bad at all Good Luck
I pulled my intake and all of the electronics & injectors for my blower install on my 06 F-150
the only part that is truly "under the dash" is about 2-3" of the valve covers. Even then, there is plenty of room for most anything.
These motors are actually pretty roomy under the hood. I sat on my radiator support and was able to reach everywhere I needed without any undue strain.
I'd post pictures, but my internet at work is blocked, so i cannot get into my photobucket account
That's good to know. The few times I've looked under hood of one it looked like it was crammed way under there. What kind of scan tool do you guys use if you need one?
Things are down right roomy in there compared to my old 05 6.0L PSD. But I must say, the old 460 was one of the easiest to work on besides the 300 6 cylinder.
