engine rotation direction
Old Aug 2, 2009 | 09:50 AM
gearhed1971's Avatar
gearhed1971
Ok,I've got a nube question,but nonetheless-which direction does a '67 289 turn?I need to hook up the tq,and don't want to spin it the wrong way.
Old Aug 2, 2009 | 10:50 AM
lew52's Avatar
lew52
Clockwise .... Lew
Old Aug 2, 2009 | 04:52 PM
gearhed1971
the crank spins clockwise as looking at it from the front?
Old Aug 2, 2009 | 05:10 PM
lew52's Avatar
lew52
Right , the only reverse rotation would be some boat motors .. as far as i know... Lew
Old Aug 2, 2009 | 05:52 PM
Beanscoot's Avatar
Beanscoot
Engine rotation direction
Imagine trying to start the engine with a crank handle. That's the way it rotates. Another way to remember the direction of rotation of the engine is to try to tighten the harmonic balancer bolt. Tightening it rotates the engine in its running direction.
So far as I know, all car and truck engines rotate this way.
Old Aug 2, 2009 | 06:15 PM
gearhed1971
So what would you recomend to achieve torque on the flexplate?To get 75 ft.lbs,the engine will turn the wrong way.I actually moved it a hair the wrong way,do you think it will hurt it?
Old Aug 2, 2009 | 06:31 PM
lew52's Avatar
lew52
No it will not hurt it , just sick a big screw driver or pry bar where you can stop the motor from moving.... Lew
Joshua Christopher
Jan 28, 2017 03:40 PM
bcamill
Apr 4, 2016 11:25 AM
plgebbia
Aug 17, 2010 11:24 PM
biker
May 25, 2010 07:06 PM
hairyboxnoogle
22
Nov 21, 2008 10:24 PM
