Tranny Device, What do you think?
Old Aug 1, 2009 | 10:07 PM
gabocar's Avatar
gabocar
Post Tranny Device, What do you think?
Serching on the net about the 4R100 torque converter problems i found this item.
i´ve been having a shuddering problem on my 99 SOHC 5,4L Navi, so sound interesting probe this
What do you think about it.
http://www.fordtransmissioncure.com/
Thanks
Old Aug 1, 2009 | 10:28 PM
MisterCMK's Avatar
MisterCMK
I am curious to know what "The Cure" actually does. I mean how the electronics inside work.
Old Aug 2, 2009 | 02:29 PM
Mustang6147's Avatar
Mustang6147
There is also an additive you can put in your tranny to stop what is called "Torque Converter Shutter"
My opinion is that would probably work, just like a reprogrammer would, but without the total reprograming of the computer...
I agree with the statement slippage causing heat which is the cause of many tranny failures, But keep in mind. The mind set of firm shifts and less slippage meens less heat being reasonable, and true. Factor in alluminum parts that crack easy. That is why Ford and all the New car companies tuned them that way. Hard shifts with a heavy load can spell trouble to. Cracked drums, and housings.
I would read the testimonials, and check with the BBB, you can do both online
Old Aug 2, 2009 | 07:26 PM
gabocar's Avatar
gabocar
Mustang6147
Could you give me the name of the additive who you mentioned?
Old Aug 2, 2009 | 09:08 PM
Mustang6147
Yup... I dont have it, Becausee I never had the problem, but it is after 10 pm here, and I dont want to call the guy, but I will tommorrow first thing
Old Aug 3, 2009 | 10:48 AM
Mustang6147
Here it is "Dr.Tranny Shutter Fix"
Parts stores carry it here locally, I think NAPA has it, but if they dont they will try to sell you other additives... I was advised Dont buy the others.
Here is a short video also. Everyone that has used it says it works.
http://www.youtube.com/watch?v=snuBptokWLE
http://www.youtube.com/watch?v=Dxp0e7zF-0A
If you use it, please update with and it does or doesnt work.
It is cheap to
dragon wagon
2004 - 2008 F150
Mar 6, 2017 09:50 PM
panic
Oct 10, 2016 11:48 AM
F250_
39
May 9, 2016 05:49 AM
ctubutis
149
May 28, 2011 08:27 AM
Bob Ayers
Electrical Systems/Wiring
32
Aug 22, 2006 11:23 AM
