Third gear in an automatic
Aug 2, 2009 | 01:16 PM
Quote:
Originally Posted by
06silvercrew
"I dont know that i agree... It isnt a manual valve body... Its the Auto matic, so its the Torqueshift."
I do trans work for a living, have yet to see one that will start off in low gear when 3rd is manually selected.
You are correct... At least in my case. If I put my shifter in 3 it starts in 3. and like that with all the rest of the gears.
Thank you, I learned something... What is the purpose of that option? or is there on.
Aug 2, 2009 | 04:47 PM
It's not an option, that's the way it works.
The purpose is for low traction launches, like snow and ice. A higher gear reduces the tendency to spin the tires when there is little traction.
Aug 2, 2009 | 07:50 PM
Mark Kovalsky
That's wrong!
Ford's standard is that if the shifter is in 2 or 3 those are the only gears the transmission will use. In 2 it will start and stay in 2nd gear. In 3 it will start and stay in 3rd gear.
Never knew that...
Aug 2, 2009 | 09:18 PM
even the old c6 worked that way and it was great in slick conditions.
94GreenTruck
45
Mar 24, 2014 10:26 AM
SRT77
Aug 12, 2008 03:22 AM
444in.ofgoodness
Mar 17, 2006 07:10 AM
shade1965
Nov 24, 2004 05:55 PM
2nd ,
3rd ,
automatic ,
automatics ,
drive ,
ford ,
gear ,
gears ,
low ,
start ,
starting ,
starts ,
stay ,
transmission ,
truck
