Tire Question
Old Aug 1, 2009 | 08:21 PM
hokie93's Avatar
hokie93
Tire Question
On an 86 F150 2WD the biggest tire you can fit is a 31x10.5 right? With an 8in wide wheel. Cause I measured it out with the stock 235/75/15 and it seems like it will rub at full lock.
Old Aug 1, 2009 | 09:40 PM
Hometown Pride's Avatar
Hometown Pride
I dont think those 31's will fit when the truck is loaded, but I could be wrong. I was looking at some, but it's seems like a waist if you cant load your truck up anymore
Old Aug 1, 2009 | 09:59 PM
Spennyman84's Avatar
Spennyman84
Here's some pics of my former trucks. The blue 1984 on the bottom right is 2wd and has 31s on it. I loved the look and it never rubbed on me.
Old Aug 2, 2009 | 06:12 AM
uncle.stosh's Avatar
uncle.stosh
It won't rub if you back out the stops a little on the knuckle.
You will lose a little turning radius though.
You can also fit up to about a 35" tire on a stock F150 if you use one of these:
Old Aug 2, 2009 | 08:57 AM
bill11012's Avatar
bill11012
Modular motor junkie
I have a stock F250 with 36.5s on it.
I use it in the yard too pull my 2wd trucks out of mud and do not take it on the road.
They rub pretty badly.
Old Aug 2, 2009 | 02:21 PM
hokie93's Avatar
hokie93
It's going to be leveled an inch and a half also. I don't know if that helps with the rubbing or if it's the width of the tire that makes it rub.
Old Aug 9, 2009 | 08:27 PM
Cnorth6525's Avatar
Cnorth6525
I have an 85 2WD styleside that had 31's on it when I bout it in Oct 08, but I put 33x1250x15 on it in Nov 08 and the only rub is on the radius arms, and that is so lightly you cant tell either from vibration or tire wear.
Old Aug 9, 2009 | 08:33 PM
uncle.stosh
Don't you guys read what other's have posted?
You can <b>BACK OUT THE STEERING STOPS</b> a little and they won't rub on the RA's any more.
You will lose a bit of turning radius though..........
Old Aug 9, 2009 | 09:38 PM
ctubutis's Avatar
ctubutis
Bwahahahahahaha!!!!!!!!
Wish I could rep that!
xaviar
Oct 17, 2012 08:36 AM
Splash67
Jun 1, 2010 03:12 PM
superdutymjh
Mar 12, 2003 09:13 AM
rabbit stu
Mar 22, 2001 10:34 PM
justdrive1
1997 - 2003 F150
Nov 9, 2000 12:27 PM
