help - broken grease fitting/ h2 remove/ pic
Old Aug 1, 2009 | 06:14 PM
19fifty4's Avatar
19fifty4
Unhappy help - broken grease fitting/ h2 remove/ pic
One of the grease fittings for the spindle/kingpin is broken off. Any suggestions on how to remove. Pliers and screwdriver were not successful. Don't want to screw up the inside of the sleeve where the kingpin goes so I want to be careful as I proceed. any suggestions?
Thanks,
mike
Old Aug 1, 2009 | 06:55 PM
mossyoak1992's Avatar
mossyoak1992
try an easy out
Old Aug 1, 2009 | 07:00 PM
mountaineer27's Avatar
mountaineer27
do you have a drill press? take an easy out and press down hard on the fitting and very slowly turn it. like with a pair of vise grips on the chuck. lot of pressure and slow constat speed. should come right out. if you dont have an easy out a flat head bit will work. lightly tap it into it to get some grip.
Old Aug 1, 2009 | 07:15 PM
thendrix's Avatar
thendrix
you can use a die grinder and cut a slot in whatever is sticking out of the spindle and then use a flathead screw driver. Or you can drill it out.
Old Aug 1, 2009 | 07:21 PM
mountaineer27
you might be able to put it in a vise and pound an apex bit into the hole. then put a 1/4 wrench on it and turn and hope to hell it doesnt break the bit
Old Aug 1, 2009 | 08:13 PM
nordvik72's Avatar
nordvik72
Ive used a small carbide bit to remove some of the greese fitting material on opposite sides just up to the threads and then kinda broke it in half while still in the hole with a small flat head and it popped right out. if that dosent work just drill and re-tap it to the correct size.
Old Aug 3, 2009 | 02:55 AM
Julies Cool F1's Avatar
Julies Cool F1
Cut a slot in the top with a die grinder, put the thing in the oven and bake at 150 degrees for about 15 minutes then put a drop of the Compound W liquid (nitrogen) on the remains of the grease fitting. It will break loose and turn out with a small screw driver.
Old Aug 3, 2009 | 07:29 AM
LM14's Avatar
LM14
Left hand drill bit.
SPark
Old Aug 3, 2009 | 08:27 PM
19fifty4's Avatar
19fifty4
Thanks for the suggestions. I will give these a try.
newguy399
Apr 14, 2014 06:39 PM
Itsme7
30
May 25, 2012 01:50 PM
Oldschool1962
Apr 27, 2011 10:24 AM
fordguy76
Jun 6, 2005 10:31 PM
debestuss
Mar 16, 2004 08:59 AM
