Staggered Ring Gaps
Old Aug 1, 2009 | 11:40 AM
Bucsfan552's Avatar
Bucsfan552
Staggered Ring Gaps
What is the recommended staggered ring gaps when installing pistons? Is it top ring 12'oclock, second ring 3 o'clock, top oil ring 6 o'clock, and bottom oil ring 9 o'clock? Or should the two oil rings be 180 from each other the top and second 180 from each other?
Thanks..
Old Aug 1, 2009 | 12:57 PM
Power_Hungry's Avatar
Power_Hungry
Former ******
This is the most common recommendation I've found for piston ring spacing. It doesn't specify which compression ring (top or bottom) should be on the left of the wrist-pin, but do them all the same for one side and swap for the other side. Same for the oil rings. Not that it should really matter, but I'm just a bit of a stickler for consistency.
Hope this helps.
Old Aug 2, 2009 | 10:21 AM
mark a.'s Avatar
mark a.
I always put the comp rings in line with the pin (180* apart) and the oil rings in line with the skirt (180* apart), in any engine I build.
deputydog03
1997 - 2003 F150
Nov 5, 2023 08:28 PM
reamer
Nov 30, 2016 06:44 PM
1953FlatJohn
23
Nov 10, 2016 05:51 PM
Obowersox26
Sep 17, 2016 09:21 PM
bsraborn
Sep 5, 2016 07:36 PM
