1990 cab to 94 cab??
Old Jul 31, 2009 | 11:32 PM
gmc.m211's Avatar
gmc.m211
hey there i was just woundering how much work it is to put the whole body off a 94 f150 4x4 extended cab long bed on a 1990 f250 4x4 extended cab long bed. the f250 is 460 efi dana 60 front just the body is shot and i found a super clean 94 f150. I would like to do the swap just want to see what im in for.
thank you
~craig~
Old Aug 1, 2009 | 01:09 PM
Diesel_Brad's Avatar
Diesel_Brad
Alot of work. Do you have some sort of means to pick up the cab? An extended cab w full interior is close to 1000lbs. Are you sure it is a D60, not a D50?
Old Aug 2, 2009 | 12:29 AM
gmc.m211's Avatar
gmc.m211
no it a dana 60 i put it in after i broke the dana 50 and the weight no problem (fork lift)
Old Aug 2, 2009 | 09:48 AM
17fordguy's Avatar
17fordguy
you can do the swap but the only thing is you have to use the dash and every thing from the 94 as the 90 will not mountup or so ive heard.
Old Aug 2, 2009 | 11:03 AM
Staveys150's Avatar
Staveys150
if that is true than. you must either get a newer wiring harness and use the 94 cluster or use the old cluster in the newer dash
Old Aug 2, 2009 | 09:20 PM
gmc.m211's Avatar
gmc.m211
well i was thinking of using the 94 wirring and just changing the main plug on the motor side??
Old Aug 2, 2009 | 09:48 PM
Blue Rebel's Avatar
Blue Rebel
VVVVVV 93 cab on 89 chassis w/ 89 interior VVVVVVV
The swap was ok, none of the plugs worked out, had to add some holes to mount the dash, lots of little things to do, most things needed a tweak or cut to get to fit.
nofx guy
15
Aug 22, 2012 07:37 PM
BroncoDually
Jan 19, 2011 12:55 PM
Ricky B
New Member Introductions
Jun 19, 2009 10:54 PM
walldog1820
Dec 26, 2005 09:44 PM
Michael Fry
International Region
Aug 11, 2005 10:26 AM
