O2 sensor heater
Old Jul 31, 2009 | 12:19 PM
frankyford's Avatar
frankyford
O2 sensor heater
I have a blown no.5 fuse in my power distribution box, the amp is 15. What is the O2 sensor heater and what does it do and could it cause my 95 F-150 302auto to run rich. Thanks
Old Jul 31, 2009 | 02:38 PM
Conanski's Avatar
Conanski
It heats the O2 sensor so it reads properly until the engine and exhaust is fully heated up. If you never drive more than a few miles at a time this is very important because the motor won't reach full heat saturation.
Old Jul 31, 2009 | 02:45 PM
frankyford's Avatar
frankyford
I put the new fuse in and it actually isrunning the same and idling worse than before. I pulled new codes and it turns out I was reading my scanner wrong, they are 3 digit codes. The codes I pulled are 334, 538, 536 and 632. The 334 code is for EVP sensor is/was high, problem is it's a new sensor on top of the EGR valve.
Old Jul 31, 2009 | 03:36 PM
alxsnmr's Avatar
alxsnmr
have you taken the EGR loose and blocked off the port to see if the engine will idle normally? I dont remember if you have stated that you replaced the EGR valve or not.
Old Jul 31, 2009 | 03:43 PM
frankyford's Avatar
frankyford
Yeah, it's a brand new EGR valve. I'm at my wits end with thing. No, I haven't blocked the ports. I did clean out the upper intake plenum when I changed the TPS. When I took it to Ford their computer said EGR has insufficient flow, I figured that was my culprit and changed the EGR, EVP sensor O2 sensor, TPS. I'm going crazy trying to figure this out, also tried changing the PCM and MAF sensor and no change.
svtcobra041
1997 - 2003 F150
Jul 15, 2010 09:19 AM
simapg
Bronco II
Sep 24, 2008 08:33 AM
applehead
20
Dec 8, 2007 11:49 PM
JOE SKI
Electrical Systems/Wiring
Oct 29, 2007 08:17 AM
f15096
May 19, 2003 09:00 PM
