window motor wiring problems
Old Jul 10, 2009 | 05:09 PM
isenegger's Avatar
isenegger
i bought the 97 f250hd knowing that the pass window didnt go down. i took the panel off and the window was held up with vise grips. and the motor was missing. i ordered a new motor. it came in today so i go out and install it. press the button and it goes down. press it to go up and nothing. the other side does the same. it unplug the motor and reverse it plug it back in and it does up but not down. i guess there is a broken wire or something. anyone have a solution or the same problem that they fixed? is there a wiring diagram around on the door window wiring? thanks!
Old Jul 10, 2009 | 05:24 PM
Sportruk's Avatar
Sportruk
If it doesn't work from the driverside either, it could be a bad switch on the driverside master panel or the wiring between the 2 doors.
Old Jul 10, 2009 | 05:32 PM
isenegger's Avatar
isenegger
ok.... i can make the window go down from both sides. but it wont go up from either side. unless i reverse the plug on the motor and then it goes up from both sides, not down. ok so is there an easy way to fix it. i dont car if it works like factory. as long as i can 1. roll the pass up/down from drivers side only or 2. roll the pass up/down from that side. any rigging i can do?
Old Jul 10, 2009 | 05:37 PM
toljoe24's Avatar
toljoe24
If this link works hear is the wiring diagram, If not get a contunity (sp) tester out and see if u have contunity thru the wire
http://www.ondemand5.com/mric/common...ab&COURTESYTAG=&
Old Jul 10, 2009 | 05:40 PM
isenegger's Avatar
isenegger
no workie.... i dont really understand the posted diagram. i dont know the ford wiring system very good at all. i thought i could cut some wires that pass between the switches and just single them out to operate their own window.
Old Jul 10, 2009 | 05:48 PM
Sportruk's Avatar
Sportruk
Remove the driverside switch panel. Unscrew the plug on the switches and swap the switches. Put the plug back on and see if the passenger window works. If the window works, you need a new switch.
Old Jul 10, 2009 | 06:20 PM
isenegger's Avatar
isenegger
yes sir i swapped them around. and it still did the same thing. does it matter if im missing a lock switch? i used a lock switch as the window switch.
Old Jul 10, 2009 | 07:37 PM
toljoe24's Avatar
toljoe24
Sorry i work for a repairshop and was trying to steal a wiring diagram off are helper program.
Old Jul 10, 2009 | 09:15 PM
Sportruk's Avatar
Sportruk
Disregard the previous diagram. I didn't realize the wire colors changed after '93.
On the diagram, the #400 Light Blue/Black is the 12V+. The #57 Black is the Negative. When the switch is at rest, both the #313 White/Violet and #314 Tan/Light Blue are connected to Negative. When the switch is pressed UP, it disconnects the White/Violet from the Negative and connects it to the 12V+ and the Tan/Light Blue remains connected to Negative. When the switch is pressed to DOWN, the Tan/Light Blue disconnects from Negative and connects to 12V+ and the White/Violet is Negative, thereby reversing the current to the motor.
You need to test to see if you are showing Negative to the White/Violet and Tan/Light Blue with the switch at rest at both switches.
Old Jul 11, 2009 | 12:57 AM
isenegger's Avatar
isenegger
^^^ i will check it tomorrow with the info u posted tomorrow. thanks
Old Jul 30, 2009 | 04:47 PM
isenegger's Avatar
isenegger
ok i bought a window switch today from the junk yard and put it in and i have the same problem. the window will go up but not back down. ahh im starting to get pissed off right about now...lol
Old Jul 30, 2009 | 05:47 PM
Sportruk's Avatar
Sportruk
Did you try the new switch in the driverside door?
The fact that the window goes up but not down, tells me the wiring is OK between the drivers door and passenger door.
Old Jul 30, 2009 | 06:22 PM
isenegger's Avatar
isenegger
well i tried the new switch on the drivers window and that window goes up and down. the switch is good. but from the drivers side the pass window does nothing. from the pass side it only goes down. i have to reverse the plug to get it back up.
Old Jul 30, 2009 | 06:35 PM
F150xlt's Avatar
F150xlt
Sounds like you're confused as to describing the problem you have.
You said this in your first post.
Originally Posted by isenegger
I ordered a new motor. it came in today so i go out and install it. press the button and it goes down. press it to go up and nothing.
Now you say this in post #11.
Old Jul 30, 2009 | 07:12 PM
isenegger's Avatar
isenegger
well between those posts i unplugged the window motor and turned the plug 180 and plugged it back in. so now the "down" button makes the window go up. either way when i press the button down it will go down. nothing when up is pressed. to get the window back up i have to reverse the plug at the motor and press down, making the window go up. ah!
