New radiator needed, How much??
Old Aug 4, 2009 | 10:07 PM
dyoungen's Avatar
dyoungen
Ok, Dave I have a question for you. I'm pretty sure I put teflon tape on almost all of the bolts. Will the oil end up in the radiator or water end up in the oil and how long will it be before I notice I missed a bolt with the tape? I haven't run the truck very much but I have checked the coolant in the radiator and don't see any oil. Or will the water pump leak the oil or water to the outside of the engine to where I can see it running down the front of the engine?
Old Aug 5, 2009 | 09:31 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Where the coolant winds up is in the oil pan.
Splash lubrication on the timing gears, so that will not put oil into the radiator.
I use teflon pipe dope paste on the threads of the bolts going into the timing gear cover.
Teflon tape, will probably work, keep looking at the bottom of the oil fill cap.
When you see a cream colored sludge under the cap, or milk shake on the dip stick, you know the first thing to look at.
Old Aug 5, 2009 | 10:01 PM
LCAM-01XA's Avatar
LCAM-01XA
I always used Permatex #2 gasket-maker for sealing bolts in water jackets, so far I haven't had one fail. Would that be safe to use here as well?
Old Aug 6, 2009 | 09:05 AM
dyoungen's Avatar
dyoungen
Thanks Dave, I"ll keep my eyes open for the water in the oil.
Old Aug 6, 2009 | 09:37 PM
Dave Sponaugle
I do think Permatex would do a fine job as well.
Since I do more plumbing than I do mechanic work, all my Permatex was hard.
But I have several bottles of pipe dope for water line fittings, natural gas line fittings and air line fittings.
Teflon tape is good, but Teflon paste is better.
Old Aug 8, 2009 | 10:17 PM
AndysFords's Avatar
AndysFords
I use paste on all pipe fitting, fuel line fittings, etc, I hate using tape.
abe
16
Nov 9, 2014 07:57 PM
Blown 331
13
Mar 25, 2012 09:14 PM
uncle.stosh
26
Mar 8, 2009 07:31 PM
bryan_johnson
Apr 11, 2005 03:05 PM
