Sponsored by: Real Truck
Faulty map sensor
Old Jul 30, 2009 | 05:54 AM
Jrs350's Avatar
Jrs350
Faulty map sensor
I am having problems with my MAP sensor in my 2008 f-350 6.4 diesel.
The truck sputters and has no passing power, my local dealer has replaced the sensor several time's and has no idea why it is failing.
The dealer told me to run cetane booster also, but am still having issues.
Old Jul 30, 2009 | 09:27 AM
senix's Avatar
senix
running a aftermarket air filter?
Old Jul 30, 2009 | 11:05 AM
Jrs350's Avatar
Jrs350
My truck has been all stock since I started having these problems, I recently added the BD Diesel boost scoop intake kit. The truck runs fine for about a month then starts to run like crap. I have a 14000 # fifth wheel camper and plan on going to the races in bristol in august, last year I had a terrible time pulling a 10000 # fifth wheel up the hills. I can only imagine what it will be like this year.
Old Jul 30, 2009 | 11:17 AM
senix's Avatar
senix
so did this kit do away with the sensor? If so then there is your answer.
I am running the Banks but it still using the factory sensor and air filter reminder too.
Old Jul 30, 2009 | 03:19 PM
Jrs350's Avatar
Jrs350
The sensor is still there, the truck run's alot better with the intake kit. Today I noticed the symptoms starting again when the sensor fails.
Old Jul 30, 2009 | 05:49 PM
dave at BD Power's Avatar
dave at BD Power
Former Vendor
We do reuse the factory sensor.
Have you installed a DPF Delete?
Have you cleaned the filter yet? it is possilble that you over oiled the filter when you cleaned it and now the oil is on the sensor. This is common on the Duramax with after market filters...no so much Ford but its worth looking at.
Hope this helps
Old Jul 30, 2009 | 08:48 PM
Jrs350's Avatar
Jrs350
The only aftermarket component on my truck is the air intake, I did state that it was the "MAP" sensor. I didn't think this sensor was mounted on the air intake, correct me if I am wrong. The dealer showed me which sensor he replaced and it was not on the air intake. I have been having this issue for over a year with the local garage not being able to help me anyway. I took it to a ford fleet center in Hamburg NY and they have been very helpful, but the problem keeps coming back. I have only had the intake kit for about a month, thats not the problem.
campbellpardee8
Jun 27, 2017 10:47 PM
rickdavis81
May 12, 2016 04:34 PM
shortbed f-150
15
Jun 27, 2011 08:06 AM
1L243
Apr 1, 2011 08:33 PM
Fordie Fish
2004 - 2008 F150
Jun 13, 2010 03:55 PM
