MAP Sensor T Fitting
Old Apr 1, 2011 | 07:06 PM
1L243's Avatar
1L243
Early 1999 F250 7.3 . I am installing a T fitting in the Map sensor line for my Boost gauge. Before I cut the line I would like to know what the ID of the map line is so I can have the proper barbed fitting on hand?? No place for delete plug on this early 99.
Old Apr 1, 2011 | 07:16 PM
brownie83's Avatar
brownie83
1/4" boost line...
Old Apr 1, 2011 | 07:20 PM
1L243's Avatar
1L243
Would that be inside diameter?
Old Apr 1, 2011 | 07:32 PM
brownie83's Avatar
brownie83
i know the line is 1/4 inch...dont know if that is inside or out though...sorry
Old Apr 1, 2011 | 07:35 PM
woodnthings's Avatar
woodnthings
1/4" barbed fittings are what you need.
General rule of thumb.....Hose is almost always sized by Inside Diameter, while pipe or tubing is Outside Diameter.
Old Apr 1, 2011 | 07:37 PM
brownie83's Avatar
brownie83
thanks for the info...i knew it was 1/4...just didnt know where it was 1/4..lol
Old Apr 1, 2011 | 07:42 PM
1L243's Avatar
1L243
Thanks.. This way I wont have to walk to the parts store should I have the wrong size!
Old Apr 1, 2011 | 07:44 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Is it for a mechanical line or electronic sensor?
Old Apr 1, 2011 | 07:48 PM
1L243's Avatar
1L243
Electronic Sensor Isspro 2
Old Apr 1, 2011 | 07:51 PM
Riffraff Diesel
PREMIUM SPONSOR
The you will need to make sure the T has one port that is 1/8" NPT threads for the sensor. You probably knew that but just want to make sure to save you a trip.
Old Apr 1, 2011 | 08:03 PM
woodnthings
Sounds like you would be better off using an Threaded AIH Plug instead of the MAP line to get your boost.
I have a mechanical gauge and it worked out great!
Old Apr 1, 2011 | 08:09 PM
brownie83's Avatar
brownie83
OP said no delete plug for an early 99...i didnt know that, but i was taking his word for it...i love my delete plug
Old Apr 1, 2011 | 08:15 PM
woodnthings
Oops.... missed that! With a little drilling and tapping, a 1/8"-27 NPT port could be added for the price of a tap if you didn't already have one.
Old Apr 1, 2011 | 08:29 PM
1L243's Avatar
1L243
I wish I could use the delete plug but they left that out of the early 99's.... Looks like a clean setup.. I thought of tapping a new port but figured the MAP line would be less likely to go south....
Old Apr 1, 2011 | 08:33 PM
1L243's Avatar
1L243
The electronic sensor is alot bigger than the boost hose connector in your picture...
PRIMERED79 SHORT BED
Dec 23, 2016 05:48 PM
Matt.gullo
Aug 19, 2016 08:39 PM
poetbig
Aug 3, 2016 04:00 PM
Jmanb13
Sep 19, 2015 07:48 PM
WILLYG247
13
Dec 22, 2010 04:09 PM
