Injectors and shot type for 7.3L
Old Aug 9, 2009 | 10:46 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Originally Posted by Pocket
Are split shots the latest and greatest? No. The most common injector upgrade is to swap them out for single shots. Split shots use more OIL, especially at idle, and require higher oil VOLUME to run correctly. They were simply added to reduce NOISE
fixed for ya
Old Aug 9, 2009 | 11:43 AM
Pocket's Avatar
Pocket
Originally Posted by PowerstrokeJunkie
fixed for ya
Yeah, after re-reading my post, it wasn't quite worded like it should have been.
Old Aug 13, 2009 | 09:19 PM
RFD_Truckie's Avatar
RFD_Truckie
Most injectors can be tuned to get the same mileage as stock injectors. If your friend is losing mileage like that, more than likely it's in the tuning.... or his right foot.
I should have stated, that his old truck was an OBS, dont remember the yr, and he now has an 03 F350. He swears that the AA codes gave him better mileage and will put those in when he needs injectors. I am not sure what tune he has, but he is not hot-rodding thats for sure, Thats not him. He tows his 5ver with it and uses it for work.
Old Apr 15, 2011 | 08:23 AM
Cat Designer's Avatar
Cat Designer
The father of the HEUI? Nope. I worked at Caterpillar and was a design engineer for 7.3L HEUI injector. No one was the father. 30-40 engineers worked on this project. There is no trim codes for the 7.3L engine. Cylinders 1-7 are the same on prime injectors AB-AF, except AC. AA and AC are non prime, AC being HO for marine. AD-AF are low mass poppet with damped lower seat impact to reduce poppet valve noise at idle. Ford made no changes like Prime, long lead, low mass poppet, and damped poppet seating. Ford didn't design the injector and had no input to the design changes. For only did things like dead head the fuel rail which were detrimental to fuel system performance. It was up to the design engineers at CAT to change the injector design to meet emissions reqs and accommodate the issues created by Ford's ill thought out changes to the vehicle. Int'l designed the engine. Again not Ford's design. If this supposed HEUI father were real, he would have known that no electronic trim codes exist. The only trim that exists is the idle fueling compensation that is achieved from signals from the 60-2 Halofex crank position sensor.
Old Apr 15, 2011 | 09:49 AM
ju015dd's Avatar
ju015dd
Old Apr 15, 2011 | 09:55 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
If you only change a few words in this paragraph, it reads out a lot like the 6.0L Powerstroke story.......
Old Apr 15, 2011 | 10:11 AM
Cat Designer
You are correct. After I left CAT, I went to Sturman Industries who designed the 6.0L fuel injector. It was licensed to Siemens Diesel and Int'l Joint Venture for manufacture. Many of the problems between Ford, Int'l, and CAT continued in the new relationships between Ford, Int'l, Siemens, and Sturman.
Old Jan 19, 2025 | 06:36 PM
Turbowhistle's Avatar
Turbowhistle
1st Gear
No crank sensor
You are wring about one thing.. everything else you said is dead on. Thats why i dont visit ford for any electronics for this engine. Only international and cat.. but this engine does NOT have a crankshaft posistion sensor it only has a camshaft position sensor... and they go out quite a bit if you do not use international parts
Old Jan 19, 2025 | 07:01 PM
John in OkieLand's Avatar
John in OkieLand
pretty sure that Halofex was a typo, for Hall Effect.
Old Jan 19, 2025 | 08:01 PM
Tpayne621's Avatar
Tpayne621
Man's first post was to correct somebody's reply that's 14 years old. 😂
JeremyH
24
Aug 23, 2020 07:55 PM
Sous
108
Jun 6, 2018 07:57 AM
tbear56657
Mar 14, 2017 02:17 AM
biggdirty7.3
Jun 1, 2016 07:27 AM
mrc00l88
May 10, 2016 10:04 AM
