Diaphram Pump
Old 06-30-2009, 03:21 PM
Tom D's Avatar
Tom D
Tom D is offline
Diaphram Pump
I recently purchased a Jabsco Model 31801-1305 diapram pump. It worked great for moving my bio around. Lately it is almost impossible to prime and pumps slow. I suspect it has nitrile diaphram and valves in it. The parts breakdown shows there is vitron parts available for it but I have been unable to contact any suppliers for it.
Any suggestions?
Tom
Old 06-30-2009, 06:17 PM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
Any suggestions?
Tom
Try here Tom: http://www.jabsco.com/distributor_lo...a-state-FL.htm
Old 06-30-2009, 09:30 PM
Tom D's Avatar
Tom D
Tom D is offline
Thanks Don
I got into their catalog but didn't have any luck with viton so I'll call and see if they're available.
Old 07-22-2009, 03:01 PM
Tom D's Avatar
Tom D
Tom D is offline
Originally Posted by fabmandelux
Well..so much for that plan. I can't replace the diaphram and valves on that pump (Jabsco 31801-1305) with oil resistant. Hell, I can't even replace them with OEM. I guess Jabsco doesn't manufacture that model any more. What a waste of money that was.
Old 07-22-2009, 07:28 PM
Rushmore X's Avatar
Rushmore X
Rushmore X is offline
Hate it when that happens, go to get replacement parts and they are no longer made. Had a motor-tool that broke a $3.00 spring and ended up having to replace the whole tool because the spring is no longer made...
Old 08-03-2009, 08:33 AM
DeepRoots's Avatar
DeepRoots
DeepRoots is offline
I deal with these pumps.
Go look at Graingers and or McMaster Carr.
They'll find something for ya.
Old 08-03-2009, 06:33 PM
Tom D's Avatar
Tom D
Tom D is offline
Tks, I'll check it out.
Old 08-10-2009, 06:32 PM
DeepRoots's Avatar
DeepRoots
I'm not 100% on your type of pump, but with any pump of this type, don't deadhead it if you can help it, and if it has check ***** on the suction side, make sure they are seating well.
Most times these pumps are condemned it is just inability to make suction, or forcing pressure through the suction side.
10-05-2013 06:16 PM
Tom Norton
02-08-2011 06:33 PM
atdoman
1966 - 1977 Early Broncos
08-02-2005 08:36 AM
Polkat
10-05-2002 09:54 PM
Shoebox
08-22-2001 02:21 PM
Quick Reply: Diaphram Pump
