Blue Smoke
Old Jul 29, 2009 | 05:29 PM
CarolinaMafia's Avatar
CarolinaMafia
Question Blue Smoke
my truck started to blow a **** load of blue smoke for the past couple of weeks. i noticed that i keep going through a lot of oil as well and you can smell it through the exhaust. i think my injector o-rings are gone but not sure. any ideaS
Old Jul 29, 2009 | 09:38 PM
sbxworship's Avatar
sbxworship
i'm no guru but that's what it sounds like to me
Old Jul 30, 2009 | 07:57 AM
Brown Falcon's Avatar
Brown Falcon
Yep... sounds like injector o-rings.
What is this a NC only thread???? haha
Old Nov 18, 2023 | 08:23 AM
Turbotop2017's Avatar
Turbotop2017
7th Gear
Blue or white smoke
you turbo seals are gone out. No onjector oring pull the right (passenger side) turbo boot off and see if there is oil in the boot. If not look at the tailpipe if you have a straight pipe and rub your finger on the inside to see if there is wet oil in it. Even the slightest wet oil. Your turbo seals are gone
Old Nov 18, 2023 | 09:43 AM
farmert's Avatar
farmert
Do you know that you replied to a 14 year old thread? I doubt the OP will even see it.
Old Nov 20, 2023 | 06:37 PM
craftsmangary's Avatar
craftsmangary
Well the rubber on those O-rings is over 25 years old, don't use anything other than Motorcraft O-ring kits. I wasn't even having any issues with my truck using oil and I pulled the injectors out to check the clearance and I found the o-ring were wearing away. They were the original with 88k original miles.
Old Nov 21, 2023 | 08:17 AM
knottyrope's Avatar
knottyrope
but we will see it
DDPJ
Sep 4, 2017 09:54 PM
jbounds
37
Feb 19, 2014 03:15 PM
Brant Bowrifle
Jan 8, 2012 02:17 AM
2006powerstroke90
Jun 13, 2011 10:00 AM
cparks
Oct 26, 2007 12:28 PM
