Name THAT PART!
Old Jul 29, 2009 | 02:49 PM
al3x's Avatar
al3x
Name THAT PART!
So I've got a part that needs to be replaced... Not sure what it is or what it does. It sits right next to the battery and it looks like battery acid has dripped on it over the years and has eaten away at the plastic. It hooks to a vacuum line and looks like it might have a filter inside of it. I'm not 100% sure about it but I'm hoping ya'll can help.
<br>
<center>
<br>
<br>
</center>
Old Jul 29, 2009 | 02:52 PM
ssquints999's Avatar
ssquints999
that is the carbon filter or charcoal don't remember what everyone calls it. it captures fuel vapors and then puts them through the TB (i'm making a guess on that since it connects to the throttle body). if i remember right you can get one a oreillys for $60 or so.
Old Jul 29, 2009 | 02:55 PM
alxsnmr's Avatar
alxsnmr
That is your charcoal canister for the gas tank vapors. It will have the gas tank vent line as well as a hose that goes to the throttle body port with a valve between the port and canister. The ECU opens the valve upon deceleration to combust the vapors trapped in the canister charcoal that are released when vacuum is applied to the charcoal. Unless it is cracked or falling apart, there isnt a need to replace it.
Old Jul 29, 2009 | 03:27 PM
*2fords*'s Avatar
*2fords*
Acid doesn't eat plastic. If there is melting or something else effecting the plastic canister, you need to find out what else is going wrong.
Old Jul 29, 2009 | 03:45 PM
alxsnmr's Avatar
alxsnmr
It really depends on the plastic and acid involved. Sulfuric acid, which is the acid used in batteries, can degrade some plastics. Not all plastics are the same, if they were all plastics would be recycled the same. So because the plastic lead-acid battery on your truck isnt degrading doesnt mean the plastic container of the Charcoal canister wont if battery acid has dripped on it. Only way to know for sure is to put some battery acid on the charcoal canister to see, though it may be really slow.
Old Jul 29, 2009 | 04:53 PM
Volvo92906's Avatar
Volvo92906
I dont really mean to steal your thread but the charcoal canister on my truck is completely open and does not run into the manifold like its supposed to. Is that bad? Its basically just sitting there in its space.. end of story. Im having performance trouble with my truck so I figure id ask.
Old Jul 29, 2009 | 05:14 PM
Old93junk's Avatar
Old93junk
Go to the wrecking yard and grab a replacement, you need to fix that........cost you maybe $5.00
Old Jul 29, 2009 | 08:11 PM
al3x's Avatar
al3x
I'm not sure if it's the acid that caused the damage. it was mainly an assumption it looks like an original part which makes it 22 years old so it could be battery acid, hot then cold air and just a general diteration. Thanks for all the input and no problem on hyjacking my thread it's cool. I think I'm going to try and find and old one. A new one runs any where from 60- 150 bucks...
Old Jul 29, 2009 | 08:25 PM
alxsnmr's Avatar
alxsnmr
Performance-wise it isnt really needed, it is just an emission part to reduce the truck's overall hydrocarbon emission. Though if it isnt connected you need to determine if the hosing for it is at as it can cause a vacuum leak into the manifold and lead to high idle condition.
Old Jul 29, 2009 | 08:39 PM
Volvo92906's Avatar
Volvo92906
Well I plugged all the open vacuum lines off. Ford did an engine swap and botched it. There is a purge valve or something where the charcoal canister goes to the purge valve and that goes to the manifold.. Thats how it is on my friends '96 anyhow. Same engine and all. But, if its just emissions theres no problem cause its blocked off anyhow. Ill still fix it though.
Old Jul 30, 2009 | 01:15 AM
al3x's Avatar
al3x
So if I was to reroute it to where the vapors just run into the intake instead of it running to the canister then to the intake would it make a diffrence. I just passed my emmis. test and if i could get rid of it that would be nice. Does it do anything improve mpg or anything else?
Old Jul 30, 2009 | 11:23 AM
alxsnmr's Avatar
alxsnmr
Your truck will smell like the old carburated cars before the charcoal canister was stuck on them from the factory. I dont recommend routing around the canister because you may also get the possiblity of not only sucking gas vapor into the manifold but raw fuel as well.
Old Jul 30, 2009 | 12:02 PM
bren_tx's Avatar
bren_tx
ive always wanted to know what that part was! with all the letters and numbers it looked like a lock to me
Old Jul 30, 2009 | 01:09 PM
xpl0sive's Avatar
xpl0sive
just block off the vaccuum lines and be done with it
JRC99408
51
Mar 15, 2021 08:25 PM
Nally427
21
Nov 2, 2020 04:43 PM
Bgrassguitar
28
Aug 22, 2013 03:32 PM
ReBilld
51
Jul 14, 2012 06:39 PM
dclack
Aug 2, 2011 01:07 PM
