IDM Mod
Old Jul 29, 2009 | 01:00 PM
rodneywar's Avatar
rodneywar
IDM Mod
I have an EDU 100A IDM. I am going to do the 140 V IDM Mod. I have searched a lot of posts, but I would like to clarify one thing- I know I need a 75K resistor, with 1% tolerance. But, which wattage do I use? 1 watt or 1/2 watt? I would rather be on the safe side and know for sure. Thank you.
Old Jul 29, 2009 | 01:34 PM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
IDM-100 and IDM-110 use a 75.0k Ohm (75,000 ohm) 1/2 watt 1% tolerance Metal Film resistor.
IDM-120 uses a 73.2k Ohm (73,200) 1/2 watt 1% tolerance Metal Film resistor.
DigiKey sells the needed resistors:
75.0KX (Violet-Green-Black-Red-Brown)
73.2KX (Violet-Orange-Red-Red-Brown)
DO NOT BUY THEM FROM RADIO SHACK. They need to be high quality.
I just did one this morning, haven't tried it yet to see if I screwed it up.
I know now that I need to buy a new teeny tiny soldering iron and/or tip...
I took the board out of the case, used a utility knife and scored the old resistor several times downt he middle. Then when I touched one side with the iron, half came right off. Then the other side, touch w/heat and comes right off.
Most of your time will be spent cleaning the old silicone off the case...
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Jul 29, 2009 | 01:44 PM
rodneywar's Avatar
rodneywar
Thanks Jim. I will have to order the resistor because no one seems to have it here in Maryland. The best i could find is 75k metal film 1/2 watt 2% tolerance. Will that work of is the tolerance too low?
Old Jul 29, 2009 | 07:36 PM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
I haven't a clue.
The specs I listed above are what was given to me, so that's what I went with. Go to DIGIKEY and get them. 5 resistors (min purchase) shipped to my door in a few days was like $6 or something stupid. Not even worth trying to find them locally.
__________________
Old Jul 29, 2009 | 07:41 PM
rodneywar's Avatar
rodneywar
Jim thanks I will order them from digikey. They are a b**** to find locally.
Old Jul 29, 2009 | 11:29 PM
aaron ford's Avatar
aaron ford
That's the one.
Some folks run the 1 watt (like me) but it is severe overkill. The stock resistor you are taking out is very small with a minimal wattage rating. In truth the 1/2 is overkill, but it is readily available.
You will also find resistors listed as 2% or +/-1%. They are one and the same. The others are 5% 10% and 20%. These are the ones to avoid.
The resistor you listed is correct.
If you opt for the 1 watt resistor you will have to deal with a chunk that is 1/2"x3/16" and has large gauge wires to deal with. It was very difficult to install and I wish I had chosen the smaller.
Aaron
Old Jul 29, 2009 | 11:54 PM
rodneywar's Avatar
rodneywar
Ok cool Iwill go up to Parkville and pick them up. thanks aaron.
Old Jul 30, 2009 | 12:00 AM
rodneywar's Avatar
rodneywar
I just want to be absolutely sure i can't fry my idm with a 2% resistor. I only have 1 spare idm to use if things go south.
Old Jul 30, 2009 | 07:05 AM
Brown Falcon's Avatar
Brown Falcon
If you need pictures I have some up in my galleries... here's a link to the post I did on it.
I have a IDM 100 as well so it will look the same inside.
https://www.ford-trucks.com/forums/8...ml#post7405113
Old Jul 30, 2009 | 08:09 AM
rodneywar's Avatar
rodneywar
Thanks Brown falcon for the write up. Reps sent
Old Jul 30, 2009 | 01:45 PM
Copedawg's Avatar
Copedawg
rodneywar, I am trying to send you a pm but you don't have that option to do so. Will you pm me with your e-mail address or e-mail me at ian.copeland@dhs.gov please?
Thanks!
