General Diesel Discussion
oil drain plug torque?
Old Jul 28, 2009 | 02:22 PM
coulon's Avatar
coulon
sorry if this is posted in the wrong area.
my boss owns 7 different ford deisel trucks, all diffrent year, models, and sizes.
a few have been dripping oil from<what seems to be the oil drain plug, and i've been asked to research and find torque values for 7.3, 6.0, and 6.4
"snug", "tight", "just past tight" wont do for this guy, so any help is appreciated
thanx for the help
Old Jul 28, 2009 | 04:41 PM
juneau76's Avatar
juneau76
Welcome to FTE! I would point you in the direction of the owner's manual for the trucks. You can view them at http://www.motorcraftservice.com/vdi...&menuIndex1=17. Do you change the drain plug gasket when the oil gets changed? That may be the issue if the plug is leaking.
Old Jul 28, 2009 | 05:55 PM
bpounds's Avatar
bpounds
Get the boss to spring for fumoto valves all around.
Old Jul 31, 2009 | 01:39 PM
Hawkeye 84's Avatar
Hawkeye 84
Do like Dad on the farm; tighten until the bolt breaks, then back off half a flat. Just kidding. ;-)
Old Jul 31, 2009 | 03:29 PM
spdmpo's Avatar
spdmpo
Fumoto valve for the win. But the correct answer is 1 grunt. If it still leaks, they probably need new washers.
Bopper
Jul 12, 2009 08:00 PM
nsaikia
Apr 1, 2008 09:06 AM
cumberlandboy
New Member Introductions
Aug 17, 2007 06:57 AM
chriswdtx
2004 - 2008 F150
Feb 28, 2006 06:14 AM
omni
Jul 1, 2004 12:56 AM
