cruise crontrol wont work
Old Jul 27, 2009 | 07:37 PM
Ravenwood Ranch's Avatar
Ravenwood Ranch
ok ive checked the fuse but im not sure if there is a relay, also my turn signals work but 4 ways dont, could my cruise control prob be tied to the turn signal switch or posible the clock spring mech?
Old Jul 28, 2009 | 12:10 AM
Ravenwood Ranch
no one knows anything about this
Old Jul 28, 2009 | 09:31 AM
frankyford's Avatar
frankyford
Have you checked to see if yours has been serviced by the dealership under the recall for the cruise control. And no the cruise and the 4ways are not tied in together.
Old Jul 28, 2009 | 09:44 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Does the horn work?
If it does the clock spring is ok.
There are 2 flasher "cans", the 4 way flasher should be located on the back side of the fuse panel. Look at the diagram.
Do a search for "05S28" Re: the master cylinder switch.
Hope this helps...
Old Jul 28, 2009 | 08:58 PM
Ravenwood Ranch
yes the horn works, no i dont know if its been serviced, also is there a relay for the cruise some where
Old Jul 28, 2009 | 09:16 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Ravenwood,
I'm unfamiliar with the cruise operation on a diesel engine.
Perhaps someone else will chime in, or you could post on the Powerstroke sub-forum
https://www.ford-trucks.com/forums/forum170/
Old Jul 28, 2009 | 09:28 PM
GLoiselle's Avatar
GLoiselle
Call Ford with your vin and see if they list yours as one thats had the cruise control switch on mast cylinder replaced.They should have record,also check wire on switch should have tag saying its been fixed, yelow or blue tag.
Old Jul 28, 2009 | 10:15 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You can check here....
http://www.ford.com/dynamic/metatags..._recall_update
Old Jul 28, 2009 | 10:17 PM
GLoiselle's Avatar
GLoiselle
forgot to adress 4 ways , check your flasher relay.
Old Jul 29, 2009 | 08:59 AM
6CylBill's Avatar
6CylBill
Originally Posted by ArdWrknTrk
Does the horn work?
Hope this helps...
My horn and cruise control went out at the same time. What is the cause of this?
Old Jul 29, 2009 | 09:41 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
If both are out I would replace the clock spring in the steering column.
Edit: Check the fuse first and always disconnect the battery when working near airbags.
(links from another thread)
http://www.angelfire.com/tx/hootbro/Clockspring.pdf
https://www.ford-trucks.com/user_gal...&albumid=37403
https://www.ford-trucks.com/forums/6...l-removal.html
https://www.ford-trucks.com/forums/a...3&d=1201131590
Maybe some of this helps?
Old Jul 29, 2009 | 09:45 AM
alxsnmr's Avatar
alxsnmr
Since the truck is a 5spd, Can you start the truck without the clutch depressed? (Obviously with the transmission in the neutral position)
Old Jul 29, 2009 | 10:05 AM
alabamabuddog's Avatar
alabamabuddog
When mine went out it was the sensor on the brake master cylinder. There is also a sliding switch on the rod on the clutch rod going to the slave cylinder master cylinder.
Old Jul 29, 2009 | 10:14 AM
6CylBill's Avatar
6CylBill
Thanks a lot!
Old Jul 29, 2009 | 10:27 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
If the cruise alone....
The TWICE recalled pressure sensor on the front of the M/C?
The same one that likely burned up my neighbors truck?
