Life expectancy of lower radiator hose.
Good call, be sure to carry some extra coolant too. My upper was slowly having a hole cut into it by the fan belt and finally gave when I was about 10 mins from advance auto. I was at about 220K when that happened, but it could've lasted longer.
Finally, something I have expertise on.
It's all about your driving habits basically! First time you find youself 50 miles out from the nearest city, at 3:00 a.m. in the morning, haven't so much as seen a barn in the last 35 miles, no cell phone reception, not properly dressed for the cool dampness that moved in unexpectantly and suddenly after midnight, and you can sense some wild beast or zombie watching, that's the life expectancy of the lower radiator hose. You can bank on it!
Thats the TRUTH!!!!
139K on my hoses. Out lasted the water pump.
fail-safe cooling mode ,page 232 owner's manual 2002 Excursion.
"If the engine reaches a preset over-temperature condition, the engine
will automatically switch to alternating cylinder operation. Each disabled
cylinder acts as an air pump and cools the engine.
When this occurs the vehicle will still operate. However:
• The engine power will be limited.
• The air conditioning system will be disabled.
Continued operation will increase the engine temperature and the engine
will completely shut down, causing steering and braking effort to
increase.""
increase.""
on
increase.""
increase.""
increase.""
increase.""
