clifford performance Intake
Old Jul 26, 2009 | 01:50 PM
8525ford's Avatar
8525ford
Question clifford performance Intake
Clifford performance sells a intake manifold to convert your old tired 1 barrel on the 6 pickles to a 2 barrel or 4 barrel with a simple adapter. Has anyone ever done this or know any info as to which carb i can get for my 85 f150. as i said before on a previous thread im removing emissons equipment so i would assume that plays a role in carb selection. any info would help me out alot. i plan on gettin a 4 barrel. they sell a weber for 600 but i dont need that this is no show truck or race truck. its a mud truck so a reasonable carb will be good
Old Jul 26, 2009 | 02:31 PM
dustybumpers's Avatar
dustybumpers
speaking from experiance, I would not do that. by the time you spend the money, and time, might as well get the right intake to begin with. the runners are longer, and the flow is much better. I paid less than $200 for my offenhauser c on ebay
Old Jul 26, 2009 | 06:35 PM
8525ford's Avatar
8525ford
Question
umm correct if im wrong but.. you say the runners are longer and flow is better, well thats the whole idea of buying this intake, and thats why they sell it. Have you installed this clifford intake before or are you just guessing. whats the intake you have from ebay?? any other help would be great
Old Jul 26, 2009 | 08:21 PM
uncle.stosh's Avatar
uncle.stosh
Both Clifford and Offy make some really nice parts for the 300 six.
I wouldn't hesitate to use either one.
Old Jul 26, 2009 | 08:51 PM
dustybumpers
I went with the offy c series, and a holly 390 cfm. I missunderstood your question earlier, and thought you wanted to put a 2, or 4bbl adapter on your stock intake.this is an offy with headers
Old Jul 26, 2009 | 10:55 PM
8525ford's Avatar
8525ford
Question
so what carb should i run with a intake. lookin to run a 4bbl, and where can i get it. summit sells a 4 bbl holley thats supposed to go on a ford truck with a 351w, will that work. What vac lines will i have to run to the carb, can i get rid of the emissions
Old Jul 27, 2009 | 04:42 AM
dustybumpers
any 4bbl that is 400cfm or less. I have vaccume advance, and power brake booster. carb can come from summet, jegs, ebay, pony carbs etc.
Old Jul 27, 2009 | 08:50 AM
8525ford's Avatar
8525ford
Question
Summit sells a holley 4bbl carb for a 80 f150 with the 351w, will that work, i think its 390cfm any good??
Old Jul 27, 2009 | 10:35 AM
4caster's Avatar
4caster
What is the part # for the carburator that you are considering? I just purchased a remanufactured Holley 4bbl carb from Summit for my 351W that is rated at 600cfm. It would probably work, but you would be wasting your money because I don't think that you would pull enough vacuum to open the secondaries.
This carburator is probably better suited for your application? http://www.holley.com/applications/C...elector/0-8007
Old Jul 27, 2009 | 12:03 PM
Chitownhillbilly's Avatar
Chitownhillbilly
Summit link...
http://www.summitracing.com/parts/HLY-0-8007/
Old Jul 27, 2009 | 12:06 PM
Chitownhillbilly
Almost new....
http://cgi.ebay.com/ebaymotors/Holle...=p4506.c0.m245
Old Jul 27, 2009 | 01:57 PM
8525ford's Avatar
8525ford
Question
thanks for all the help and info, i was lookin on the holley website and in the list of things the carb has
<LI class=feature>Vacuum secondaries allow use on wide variety of vehiclesElectric choke for easy warm up
Single feed fuel inlet
1 timed (spark) port, 1 full vacuum, and 1 PCV port
Intended for small V-8 or 6 cyl. engines & 2 x 4 street tunnel ram set-ups
Ford A/T kickdown, does not work with A.O.D. transmissions
what is the 1 timed spark port for?? is that for the dizzy or is the full vac port for that? also with the connector for the elec choke plug into my factory harness connector
Old Jul 27, 2009 | 02:04 PM
4caster's Avatar
4caster
timed spark port S/B for dizzy.
Old Jul 27, 2009 | 04:58 PM
8525ford's Avatar
8525ford
was lookin at a eddy carb for 250 elec choke 600cfm. obviously better than the holley at 350$ and flows 390cfm. what would happen if i got to high cfm carb. run lean?
Old Jul 27, 2009 | 05:39 PM
8525ford's Avatar
8525ford
also one last ?. i was looking at this intake and it says wont work with factory manifold. why? manifold to big. Also with any type of header work, i was lookin into the heddman header on summits website. Dustybumpers you should know this one, i see in the picture you have headers on yours what kind are they
