clifford performance Intake
Old Aug 12, 2009 | 09:48 AM
  #46
8525ford's Avatar
8525ford
Question
What vehicles can i get this fro (primarliy trucks) certain model/ year range to look for im going to the jy this weekend so need some trucks to look for thanks
Old Aug 12, 2009 | 11:46 AM
  #47
hittman1422's Avatar
hittman1422
just ask about a ford duraspark ignition, they came in ALOT from what i understand.... your best bet would be our generation of F-series or the next generation i'd think.
Old Aug 12, 2009 | 12:04 PM
  #48
86bigred's Avatar
86bigred
there is this option.$157.87 a little pricey. but new connectors,and not old dry rotted wires.
http://www.painlessperformance.com/w...arge/30812.jpg
Old Aug 12, 2009 | 06:19 PM
  #49
8525ford's Avatar
8525ford
dustybumpers i have the clifford intake and holley 390, when i go to mount the carb onto the manifold the same way you had it, the mounting holes on the carb dont line up with the spacer on the manifold?? also what should i do about the linkage. you had it mounted parralle with the valve cover and the throttle linkage on the truck goes the total opposite? im so confused how do i mount a holley 390cfm carb to a clifford intake. do i need to buy some other kit, am i missing something. need help fast
Old Aug 12, 2009 | 07:21 PM
  #50
dustybumpers's Avatar
dustybumpers
no, I have a offenhouser c series. you have to mount the carb with outside fuel bowl on yours toward the valve cover. you have a duel plane manifold, which is actually more street friendly. you can get a locar throttle cable to work that one, here is a link to a friend of mine who is makeing the build you are asking about
390 to 300 swap photos ( <!-- BEGIN TEMPLATE: threadbit_pagelink -->1 <!-- END TEMPLATE: threadbit_pagelink --><!-- BEGIN TEMPLATE: threadbit_pagelink -->2 <!-- END TEMPLATE: threadbit_pagelink --><!-- BEGIN TEMPLATE: threadbit_pagelink -->3 <!-- END TEMPLATE: threadbit_pagelink --><!-- BEGIN TEMPLATE: threadbit_pagelink -->4 <!-- END TEMPLATE: threadbit_pagelink --><!-- BEGIN TEMPLATE: threadbit_pagelink -->5 <!-- END TEMPLATE: threadbit_pagelink -->)
F-250 restorer
Old Aug 12, 2009 | 08:26 PM
  #51
8525ford's Avatar
8525ford
so the fuel inlet tube has to be facing the valve cover is what your saying?? if thats true then the throttle linkage hits off the manifold. i have the spacer installed and carb on top of it. do i need another spacer??
Old Aug 12, 2009 | 08:40 PM
  #52
8525ford's Avatar
8525ford
the truck is a manual by the way
Old Aug 13, 2009 | 07:55 PM
  #53
dustybumpers
post a picture on here, I'm not sure what you mean. I had to use a spacer to allow my carb because of clearance of the throttle linkage. there should be no need for 2 spacers.
Old Aug 13, 2009 | 09:12 PM
  #54
8525ford's Avatar
8525ford
ok i got that spacing figured out. Now which way do i mount it. Does the fuel inlet tube face the valve cover, or does it face the pass. side fender? it can only go those 2 ways so im thinkin it has to face the valve cover so i can hook up my linkage.
What mods will i have to do for my linkage to hook up. need to be longer cable, bracketry? im doing this proj this weekend.
also one last thing check these links out and tell me if this dist. coil. and ign module will work
this is the dizzy...
http://shop.advanceautoparts.com/web...EAMS_516417378___
coil
http://shop.advanceautoparts.com/web...EAMS_994406870___
ign module
http://shop.advanceautoparts.com/web...EAMS_994419567___
will these parts work. are these duraspark 2?
Old Aug 14, 2009 | 09:37 AM
  #55
8525ford's Avatar
8525ford
Question
any input guys??
Old Aug 14, 2009 | 07:46 PM
  #56
dustybumpers
this is good http://shop.advanceautoparts.com/web...EAMS_516417378___
with this http://www.carbdford.com/tech/HEI/hei.htm and a good 12 volt coil off a 86 or newer ford.
Old Aug 15, 2009 | 09:46 AM
  #57
8525ford's Avatar
8525ford
i already ordered the coil dist and module i had posted. no one wrote me back so i have to try it now. Im going to the jy today to find a ds2 wiring harness. hope it all works
Old Aug 15, 2009 | 03:51 PM
  #58
dustybumpers
it will work fine, I still have 2 trucks wired like that. sorry to not get back to you, have been working lot's of ot. next time pm me, I'll get that when I check the md chapter b/s. forum
Old Aug 16, 2009 | 11:18 PM
  #59
8525ford's Avatar
8525ford
Im new to fords as i said before. I have no idea how to wire this duraspark 2 up. I bought the painless ds2 harness and what wires do i have to splice and what factory connectors can i use. i have no idea where to start. I know this is probably simple for you guys but a newbie like me to old fords its diff. somebody explain in the simpliest possible way how to wire this up. thanks. i also got a ac delco round coil. it has 2 + and - terminals on the side. what do i wire to that?????????????????
Old Aug 18, 2009 | 04:12 PM
  #60
8525ford's Avatar
8525ford
any help guys
