A/C turns off by itself problem
Old Jul 25, 2009 | 08:43 PM
excursion0005's Avatar
excursion0005
Hello,'
I have a 2005 Excursion and the A/C keeps going off while driving. I have to turn the control to off, wait a few minutes and turn it back on. My ford dealership changed the evaporator but that did no do the trick. I can't get it to happen when they are in the truck with me. Could the compressor be going bad? or is the switch or wiring going bad? When the problem happened today I popped the hood and i turned the a/c off and back on and i did not hear the compressor click. Should it click like it is engaged? As you can see I need some help if possible.. Thanks Randy H
Old Jul 30, 2009 | 08:31 PM
blacklab3113's Avatar
blacklab3113
I had the same thing happen on the suburban I had prior to my Excursion. It was the compressor. It kicked itself on and off. They diagnosed it very quickly and replaced it with no more problems. I would have them check the compressor which was one of the first things they should have done. I believe I would find a new mechanic.............
Old Aug 1, 2009 | 06:36 PM
bigrigmike's Avatar
bigrigmike
my ex does the same thing but it works when i have the fan speed on high but not on the other speeds.
Old Aug 1, 2009 | 06:57 PM
cbradford's Avatar
cbradford
Chances are it's not the compressor, it's the clutch or pressure switch, relay or could be low on charge.
Old Aug 7, 2009 | 12:31 AM
GreenExcursion's Avatar
GreenExcursion
Had this happen a few times... no idea.
Old Aug 7, 2009 | 10:39 PM
bigrigmike's Avatar
bigrigmike
let me be more clear with mine, it works on all speeds but sometimes it will shut off when i apply the brakes then stay off for awhile unless i put the fan speed on high, then it comes back on, but not with the other speeds.
willtim1234
May 14, 2017 05:09 PM
PasoF450
6.7L Power Stroke Diesel
Mar 5, 2017 04:13 AM
kuboy
2004 - 2008 F150
Oct 15, 2012 05:09 AM
cavitation
Apr 28, 2010 10:16 AM
yosemite
Jul 11, 2003 09:45 AM
