Lean bank issue
Old Jul 24, 2009 | 01:42 PM
BiggDogg77's Avatar
BiggDogg77
Lean bank issue
Getting a lean bank code and wondering if anyone has any ideas on what to check for to fix this??? I have an 03 X with a V10 with about 76000 miles.
Old Jul 24, 2009 | 05:26 PM
1's Avatar
The parts store will push oxygen sensors at you. I would suggest looking for a cracked vacuum hose or another air leak on that side of the motor. Your likely getting air in afte rthe MAF sensor so the computer doesnt know its there and isnt providing enough fuel for that air. Being its one bank Id concentrate my inspection around that side of the motor. This costs nothing and you will likely find an old cracked vacuum hose that needs replacing or something else fairly simple. Throwing oxygen sensors at it like some will tell you is the wrong way to go. If you really suspect the )2 sensor swap em from one side to the other and see if the porblme moves. I think your problem is an air leak after the MAF somewhere.
Old Jul 24, 2009 | 09:05 PM
Monsta's Avatar
Monsta
Sit. Stay.
Most lean issues I've seen/heard of derive from the PCV hose being cracked on the inside of the bend. Have you pulled it off to inspect it?
Old Jul 24, 2009 | 10:20 PM
Cardiac69's Avatar
Cardiac69
Also, I generated a lean code from having the plug come loose on the bottom of the MAF, which allows air to get sucked in AFTER the MAF. This happens quite often, I guess.
Old Jul 25, 2009 | 12:31 AM
EXv10's Avatar
EXv10
My bank if kinda lean right now too.
pnp522
Modular V8 (4.6L, 5.4L)
Jul 15, 2015 04:40 PM
jasonhaysler
Jun 27, 2015 12:33 PM
CAPPY00
3.8 & 4.2L V6
Mar 30, 2009 12:58 PM
surferbum
May 28, 2007 01:54 PM
Medster
3.0L V6
Jan 10, 2005 05:05 AM
