Sponsored by: Auxito
need some experienced help with the VSS problem.
Old Jul 29, 2009 | 09:34 PM
pintopower8's Avatar
pintopower8
remove the intake tube, and clean the throttle body with a suitable fuel injection cleaner, flip the throttle valve open and clean the backside. Spray and clean out the IAC passage. With the engine running spray cleaner into the intake until it starts making the engine miss. allow this to happen for a while, then let it shut down. Spray the rest of the cleaner into the intake. Allow to sit for 1/2hr- 1 hour. Start the engine up and hold at 2500 RPMS until the smoke clears out. Then proceed to change your engine oil, filter, and spark plugs, as it will probably dilute the oil through the piston rings.
Old Jul 29, 2009 | 11:23 PM
Thudpucker's Avatar
Thudpucker
Thanks, I think!
Dick
2shus
Jul 11, 2011 11:33 AM
tloo13
26
Jun 10, 2010 07:48 PM
460
Jul 4, 2008 07:42 AM
freddo32
1997 - 2003 F150
Nov 3, 2003 10:42 PM
