Many sensors reading too high voltage
Take for example the TPS. There's a coil (resistor) inside with a wiper that moves between the high volt and low (ground) volt reference that allows the signal wire to vary voltage proportionally between the high and low volt references depending on the wiper's position between the two. The wiper can't get close enough to either the high or low volt reference to read exactly the same as each reference.
It's kind of hard to put into words, but I don't have a diagram or anything to help explain.
The following users liked this post:
on
Check the reference voltage on the orange wire at the TPS, MAP, and EVP sensors. It should read 5V with the key on, engine off -- any higher would indicate a failed voltage regulator in the computer or a short to +12V somewhere between the computer and the sensors. I'm leaning towards an internal fault since there is no external 5V supply to the ECT and ACT. The fuel pressure might be slightly low, but it should still be within the normal operating range.
quick question though, what do you guys think would be the cause of too much voltage on the signal return wire of the EVP sensor? Same results with a rebuilt ecu and original ecu….
im thinking of connecting a jumper wire from battery negative to the ecu pin 46 that controls the signal return to see if there’s any change in voltage….
thanking you guys in advance
great info thank you!!!!
SideWinder4.9l
07-30-2011 08:29 PM
