I am getting a antenna fault for my Sirius on my 08 F450. Can someone point me in the direction of the module so I can make sure the antenna plug is firmly seated?
Thanks.
I don't know about OE, but if you can't find the answer, I would pull the right A pillar trim and look for the wire coming down from the roof. I suspect it would go under the glove box and either the box will be under the glove box or on up near the radio. Good luck.
