Not always. There was at least one change to the T18 and many of them, like my '75 F150, reverse is right and back against the seat.
EZ way to tell a Warner 4 speed from a New Process 435 4 speed without leaving the cab.
Look towards the top of the shift tower. If there are two pins directly opposite each other protruding from the tower...it's a New Process 435.
No pins: Warner.
The New Process 435 4 speed uses a shift lever retainer cap that has two notches on it. The cap is retained to the shift tower by the two pins.
The Warner shift lever retainer cap threads on/off.
------------------------------------------------- 1965/67 F100/350 352 / 1968/76 F100/350 360/390 / 1965/71 Galaxie/LTD 352/390
C5AZ6375K .. 352/360 Flywheel / (6) 5/16" pressure plate attaching holes on a 12 3/8" bolt circle / Uses an 11" clutch.
C5AZ6375L .. 390 Flywheel / (6) 5/16" pressure plate attaching holes on a 12 7/8" bolt circle / Uses an 11 1/2" clutch.
