Sooo much money
Old Jul 23, 2009 | 05:45 PM
393STROKER's Avatar
393STROKER
Did you try swapping out the distributor? My `90 was cutting out because the PIP sensor in the distributor was bad ,and after it got hot enough it would just cut the engine off.After it cooled back down it would start back up again.As far as it running bad,going around corners and turns,it sounds like a fuel delivery problem.
Old Jul 24, 2009 | 07:43 AM
moethomas80's Avatar
moethomas80
Thank you...I appreciate the help.
JT
