35" vs 37" tires?
Old Jul 22, 2009 | 07:07 AM
amsk8er1983's Avatar
amsk8er1983
35" vs 37" tires?
I am just trying to play all my cards right. If I do a 6" lift I really want to run 37" tires but I don't want to ruin my tranny I have the 6.0 and would 37" be hard on my tranny? and would I be able to tow a 30ft. camper? also would I have to re do my gears and what is the average cost for doing this? or would it just be safer to run the 35" tires?
Old Jul 22, 2009 | 07:50 AM
EX_05_v10_Limited's Avatar
EX_05_v10_Limited
With a six inch lift you are only going to be able to fit 35" tires in there... I asked the same question on this board and got that answer!
Old Jul 22, 2009 | 09:23 AM
CanadianSmokie's Avatar
CanadianSmokie
Not sure on tranny problems but I run 35's with a 2-3" lift... 37's will be fine with 6". Worst case, you may have to heat and bend the inner fender a bit for rub but I doubt it.
Old Jul 22, 2009 | 12:07 PM
Excursioncamp's Avatar
Excursioncamp
I also have a 6" lift and run 37's. The shop shaved off just a little bit of the lower front bumper / air dam. I still get a little rub at full lock, but nothing to worry about.
I tow a 32' travel trailer and have had no problems with the transmission. It did obviously affect the RPMs, but with my DP Tuner, I've got enough horsepower and torque to drive comfortably.
Good luck.
Old Jul 22, 2009 | 04:25 PM
amsk8er1983
hey xcamp what 6" lift do you have and how wide are your tires? did you have to extend anything driveshaft, brake lines etc. do you have any pics? also I have the edge juice platnium so if I put it in tow mode you think I would be ok?
Old Jul 22, 2009 | 06:32 PM
YellowSled's Avatar
YellowSled
2 inch lift, running 35's i would bet 37's would be just fine on a 6' lift
Old Jul 22, 2009 | 07:02 PM
soutthpaw's Avatar
soutthpaw
I had 35's on my Ex with 4 inch rancho lift. now running 255/85r16's. (an unusual size but I like tall narrow tires) they also ride much better than the BFGs i had prior to that. I have 16x8 rims but had to weld a bit of metal onto the steering stop as the edge of the tires would rub on the springs at full lock. I was able to grind off a whole lot of metal off the stops now and get tighter turning radius. 37's will fit with a 6" lift. Though I bet those folks that responded above have not done any serious off roading and got the steering at full lock and full flex... 37"s will rub unless you have them offset more so they run futher out and you have trimmed/modded the fender skirts...
consider a transgo shift kit for the tranny (temp gauge too if it doesnt have one).... it will be fine as long as you are sensible when towing....
Old Jul 22, 2009 | 07:59 PM
Excursioncamp
I've got a Skyjacker lift, all springs, no blocks. 20" (by 10") KMC XD Rockstars with Terra Grapplers, 355-60-20 (basically 37" x 13.5"). I did not have any modifications to the driveline or brakelines. I did install a dual steering stabilizer which helps keep it straight. Another mod are Airlift 5000 rear bags with a 6" lift.
My DP Tuner has 2 tow mode, 60 and 80 hp, and both do a great job in providing extra power - it drives great (32' dutchmen, 9,000+ pound trailer).
I do not do any serious off-roading, but I'm sure there would additional rubbing if I did. I've got lots of pictures that I can send you, but I haven't posted enough on this forum to post pics yet.
Old Jul 22, 2009 | 10:49 PM
amsk8er1983
xcamp you should send me some photos my email is amsk8er1983@yahoo.com also do you have any driveline vibration?
Old Jul 23, 2009 | 10:29 AM
Krazyninja's Avatar
Krazyninja
the transmission should be fine without the re-gear but watch out for high EGTs on the uphills especially if you run a chip or tuner. My EGTs run high when towing because I have not re-geared with my 37s. I get a driveline vibration at around 65 mph but it is not bad.
Old Jul 23, 2009 | 01:10 PM
soutthpaw's Avatar
soutthpaw
Just posted some pics of my new tires here for comparison. if you go to my gallery you can see what it looked like with 315/75r16's which are equal to 35's on a 4 inch lift
https://www.ford-trucks.com/forums/8...ml#post7092395
sanchezp_09
6.7L Power Stroke Diesel
64
Jun 6, 2019 04:14 PM
BigBlue13
Mar 21, 2017 08:57 PM
emmagator
Sep 10, 2016 03:26 PM
800screws
Oct 14, 2015 04:00 PM
Neal 97 250
All Things Towing
19
Jun 14, 2011 10:25 AM
