C6 Transmissions
Old Jul 25, 2009 | 12:29 AM
1977f150xlt's Avatar
1977f150xlt
you plan on running a NP-205 married behind your transmission?, i am going to assume yes,
if so yes a NP-205 transfer case will fit behind a AOD or E4OD
what i found with my truck, we had to get a 4x4 extension piece that goes from the transmission to the transfer case, also we had to get my AOD converted to 4x4, thus the longer tail shaft had to be put in, plus we got them to rebuild and toughen up the AOD with extra clutches and a mild shift kit,
also the NP-205 was not used by Ford in the 80s, but luckily the bolt pattern did not change,
there is one slight easy mod, all you have to do is grind out a notch in the extension housing so the transfer case shifter clears, simple mod, took me a few minutes, and was easy, there was lots of aluminum in the spot that needs to be notched, no problemo,
also check out my youtube video, you will see my driveline before it was installed, and you can see my project,
http://www.youtube.com/watch?v=Zm8aQbDChpw&fmt=18
best of luck with your project, also keep us posted on it,
-Brent
Coastal68
32
Sep 16, 2015 02:12 PM
john72ss
Sep 3, 2015 10:21 AM
tassmannn
Jul 19, 2014 11:08 AM
ktm747
Jun 1, 2011 08:09 PM
91bottlerocket
Aug 7, 2010 05:35 PM
