1978 - 1996 Big Bronco
96 5.0 whine
Old Jul 21, 2009 | 09:13 PM
Boxer's Bronco's Avatar
Boxer's Bronco
96 5.0 whine
Hey guys. New guy here. Always liked Broncos since my dad bought a 86 brand new back in the day. Got a 96 5.0 with that bad ford whine in the pulleys. What is that classic whine you here from alot of those year model 5.0s? And how do I get rid of that on my Bronc? Not when you turn the wheels mind you, just at idle.
Old Jul 21, 2009 | 09:40 PM
g_k50's Avatar
g_k50
Power steering fluid in the resiviour?
Old Jul 21, 2009 | 09:48 PM
Boxer's Bronco
It's full. Could be the p.s. pump. But I really dont think it is. I'm thinking maybe the smog pump. I had a 93 ford pickup that did it several years back and you here that same whine from alot of those year model 5.0s. Just a distinct whine at idle and gets louder as you give gas. Anyway, its on my list of first things to fix on my new Bronco. May try to bypass the smog pump.
Old Jul 21, 2009 | 09:57 PM
ottawaguy's Avatar
ottawaguy
Well the power steering pumps in these trucks are famous for their "Whine".
If you do a search on Saginaw power steering pump conversions, you will find all you need to address that issue.
However, that may not be your issue, but I can not tell without hearing it. Other pulleys and whatnot make their own sounds as they are on their way out, but it can be hard to tell sometimes. Perhaps with an automotive stethoscope.
Hope you figure it out
Old Jul 22, 2009 | 11:24 PM
g_k50's Avatar
g_k50
I have a serpentine belt on my 1990. My mind is boggled at the method to bypass the smog pump?
Old Jul 23, 2009 | 08:54 AM
ottawaguy's Avatar
ottawaguy
If you are certain it is the smog pump...why not change it??????
Why try to bypass it?...
Old Jul 23, 2009 | 09:56 AM
wileec's Avatar
wileec
There are many rollers that may be whining you need a vacuum hose to listen to each one replace the roller the whines. Mine was the tensioner pulley..
F150MUTT
2015 - 2020 F150
Aug 12, 2017 02:29 PM
shetluck
Mar 16, 2014 04:00 PM
TSBRONCO
Mar 23, 2005 02:24 PM
Ranger4.0L
Sep 18, 2004 06:57 PM
sereynolds
Dec 22, 2002 05:14 PM
