75 ford 360 engine swap
Old Jul 24, 2009 | 11:07 AM
bigtrucks1's Avatar
bigtrucks1
now would the stock rear end work i dont no the ratio but i do no that it is a ford 9 inch rear
Old Jul 24, 2009 | 01:56 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
A Ford 9 inch is perfectly fine.
Josh
Old Jul 24, 2009 | 04:35 PM
bigtrucks1's Avatar
bigtrucks1
how much difference will it make to have the heads done for cj sized valves. what for pistons would be good for this motor
also wondering how hard it would be to take out the factory bench seat and replace with a set of bucket seats with a center concel
Old Jul 24, 2009 | 04:49 PM
85e150's Avatar
85e150
Before you put in the CJ sized valves, you have to decide how much motor you are going to build. I suggest you see the FE forum, and read the FAQ's at the top.
You might want to read this book:
http://www.amazon.com/How-Rebuild-BI.../dp/0895860708
The bigger valves add power capability in a performance engine.
There are detailed engine builds discussed on the FE forum, as well as all the general stuff.
Your next step, imo, is budget and goal based on budget. Then research, then determine method--diy, find a shop, buy a complete engine.
Old Jul 25, 2009 | 07:54 PM
bigtrucks1's Avatar
bigtrucks1
the 360 i mostly looking for low end force with out busting the check book.
lindenj
Nov 23, 2016 07:54 AM
digitalderek
Mar 1, 2016 02:50 PM
chrishen
Dec 8, 2015 12:22 PM
xlt351
New Member Introductions
Jul 23, 2015 08:31 AM
dhobdey1
22
Jan 4, 2010 09:20 PM
