01 F150 Supercrew Rear end whine
I have a 2001 F-150 Supercrew with a 5.4, 121000 miles, and it has the tow package. For the last couple of weeks i have noticed a loud whine coming from the rear of the truck. I took the wheels off today and checked the brakes, they are fine. I put the truck in neutral and turned the axle and hear grinding and whining coming from the rear end. I had this rebuilt by the ford house at around 80k. Is the rear end going out again? I am going to figure out how to check the fluid. Any help is appreciated.
I checked the fluid through the plug on the drivers side rear of the rear end, it came running out when the plug was removed. I seen some posts where they were told to try adding a tube of friction modifier. If i do this will i need to fill up the rear end with fluid after? Or is there another spot to add fluid, or friction modifier? Thanks for the help.
2000xp8
04-17-2015 04:13 PM
trooper180
12-04-2012 05:23 AM
