The trun signal flasher unit started buzzing
Jul 21, 2009 | 10:30 AM
2002 F-350 7.3 L
Diesel Auto Trans
The trun signal flasher unit started buzzing - If I turn on the turn signals or touch the
brake pedal the buzzing stops.
Replaced the 5-pin flasher Unit - no change.
Checked grounds at dash - no change
I'm thinging that there is a back feed or a ground problem.
Has anyone experienced this and if so what was the fix.
Thanks
Dan
Jul 21, 2009 | 10:37 AM
Are you SURE you changed the turn signal flasher and NOT the 4-way flasher?
Jul 21, 2009 | 09:08 PM
I could only find one flasher - a 5 pin flasher that operates the turnsignals and the 4 - way flasher.
I can feel the flasher click (Flashing) when the turn signals or 4-way flashers are operating - so I am sure there is only one flasher.
AllData shows only one flasher for the 2002 F-350.
I double checked the grounds today - no change.
I disconnected the brake lamp switch and no change.
It appears to be a feed back through the turn signal multifunction switch.
When I disconnected the multifunction switch the buzzing stopped.
I hate to replace the multifunction switch without knowing for sure that a new switch will fix the problem.
A new switch is $120 - not cheap.
Jul 22, 2009 | 11:31 AM
F250 Flasher
Hello. I have similar problem. My directionals are intermittant. Both right and left. Where is the 5 pin flasher and how much did it cost?
Jul 23, 2009 | 11:52 PM
I found my 5 pin flasher on the right side of the steering column - way high up in the dash.
It was in a large connector box with a plastic cover.
Cost about $17 at Autozone.
I ordered a new Multifunction Switch (turn signal, wiper, 4 way flasher combo switch) $70 @ autopartswarehouse.com
I think the problem that I have will be curred with the replacement switch.
I'll keep you all up to speed with the results.
Thanks
Dan
Jul 29, 2009 | 09:25 AM
I replaced the multi-function switch (Turn signal switch) and the flasher buzzing noise stopped.
Seemed to fix the problem.
Hope this helps others
Dan
Jul 29, 2009 | 09:36 AM
Great! Thanks for the info!
clouden
May 2, 2011 12:05 AM
rockcrawlerdude
27
Oct 11, 2010 02:23 PM
77_150_460
Jan 25, 2010 06:14 PM
SeminoleSlim
25
Jul 15, 2008 10:32 PM
thedaddycat
Oil & Lubrication
Feb 27, 2008 06:12 AM
2002 ,
buzzing ,
duty ,
f250 ,
f350 ,
flasher ,
ford ,
noise ,
problem ,
relay ,
signal ,
stop ,
super ,
truck ,
trun ,
turn
