seam sealer
Old Jul 21, 2009 | 10:22 AM
reg1952's Avatar
reg1952
seam sealer
Getting close to resealing joints in my cab.Am I better to use the seam sealer in a caulking tube or from a can? I dont know if you can brush out the sealer that comes in the tube.Thanks
Old Jul 21, 2009 | 10:26 AM
sdetweil's Avatar
sdetweil
I used the Eastwood brush on in a can.. (actually 2 cans)
recent pic in the Darksider wiring topic
https://www.ford-trucks.com/forums/8...ml#post7742254
sam
Old Jul 21, 2009 | 10:33 AM
tinman52's Avatar
tinman52
Welder User
3M also makes a brushable seam sealer, available at most auto paint stores.....T/M
Old Jul 21, 2009 | 11:38 AM
CharlieLed's Avatar
CharlieLed
I never even considered using a brush-on sealer, the caulking tube is just so easy to use and easy to control where the sealer goes. I use 3M 8308 2-part sealer for the "important" areas (like around the doors) and various other sealers for the floors, etc.
Old Jul 21, 2009 | 03:31 PM
51f1truck's Avatar
51f1truck
I used the 3M seam sealer in a caulk tube. I found that there is a solvent made by 3M for use with this product but noticed that basic "carb cleaner" contained most of the same solvents. The reason this was important was that I wore rubber gloves and applied the seam sealer in small sections of the seam at a time. Then sprayed my finger quickly with the carb cleaner and used my finger to spread the seam sealer out nicely. The seam sealer seemed to dry so fast that I could never get it to lay down as smooth without the finger/solvent trick. Maybe others have a better approach but this worked well for me. I even let this dry for a couple of days and made a second pass before spraying any primer/surfacer over it.
Good luck,
Fred
Adamswd
Aug 29, 2012 11:35 AM
Smitty49
Aug 26, 2012 03:02 PM
berry1234
Sep 30, 2010 12:35 PM
mechanicblue3
Paint & Bodywork
Oct 25, 2007 09:00 AM
sancochojoe
Mar 21, 2005 04:59 PM
