seam sealer floor
Old Oct 25, 2007 | 06:43 AM
mechanicblue3's Avatar
mechanicblue3
seam sealer floor
I am just about finished replacing the cab floor in a 48 f1. So here a log of seams to seal. there are many choices. Do any of you have experience or comments about Eastwood's brushable seam sealer?
Old Oct 25, 2007 | 09:00 AM
blue68f100's Avatar
blue68f100
I've used the 3m brush seam sealer, and the caulk. I would think there the same. The brush is for wide seams and is was was used at factory in the 60's and early 70's. Once the can is opened you must use it up, it will not keep. Unless you purge the oxygen from the can with inert gas. Either will work, the caulk is easer and less work if you have access to all of the joints.
jvmcc
Jun 3, 2015 09:25 PM
center97
2009 - 2014 F150
Dec 3, 2013 04:54 AM
SCRAPHEAP51
Sep 7, 2013 07:04 AM
wooddyusa
Paint & Bodywork
Aug 19, 2013 01:01 PM
berry1234
Sep 30, 2010 12:35 PM
