No overdrive
I've got a 2002 f450, v10, 4r100 w/pto, its a dumptruck. Its got 72k on it.
It runs great but does not shift from 3-4 ever. I used to think it did but it was just the TC locking. I have 4:88's so the motors turning about 3k at 55mph, which is what got me checking things out, that and the mpg.
It doesn't throw a code if I don't push the od button, but If I switch it on and off a few times and start and stop a few times I get PO783 (no 3-4 shift) not very helpful since I already know that.
With OD on, once I get going around 40mph and let off I coast until I slow enough, then engine braking in 2nd and 1st. With OD off I have engine braking 3-2-1.
I changed all the fluids when I bought the truck, and the trans fluid was a little brownish, didn't smell bad, but I don't think the previous owner ever changed it.
I read 2002 has problems with the solenoid body so I replaced it when I changed the fluid. There was a bit of sludge on the pan magnet , but no noticable metal shaving.
I guess that leaves bad OD clutch, or 3-4 valve in valve body. Since I tow my equipment a lot of times and I never go more then 10 miles or so to jobsites, if I turn off OD, will I hurt anything in the trans if I keep driving and towing?
There are other things that can cause overdrive failure. In my case, I narrowed it down to what I thought was failure of the bonded overdrive piston. I was almost right, but it was the feed bolt the holds the intermediate/overdrive piston assembly to the case. It was loose so the loss of pressure led to failure. It dosen't take long to fry the overdrive clutches when this happens.
I decided to rebuild the trans myself, and its a good thing because I had burned overdrive clutches. I did most of the upgrades, alto clutches, steel 6 pinions planet, triple disk billet convertor, etc. I ended up buying some tools kits off ebay, rotunda t89t-7000, and t99t-1000 I think they are. they have the tools that are harder to make to do the rebuild.
I would start off getting an ATSG manual if you decide to fix it yourself.
here a good link that helped me.
Complete E4OD High Performance T
