Dana 44 dimensions?
Old Jul 21, 2009 | 07:24 AM
Brown Falcon's Avatar
Brown Falcon
Dana 44 dimensions?
What are the dimension on the dana 44 in a 78-79 Bronco or F150?
Hub to hub and also spring center to spring center?
Old Jul 21, 2009 | 11:58 AM
ChaseTruck754's Avatar
ChaseTruck754
I have one listed for sale right now so I just took a few measurements.
Wheel mounting surface (WMS) to WMS is +/-68" and spring center to spring center is +/- 31.5"
Old Jul 21, 2009 | 12:03 PM
75F350's Avatar
75F350
Steve, that is a good measurement for the 78/9 high pinion axle with 8 lug spindles and hubs. The OP was asking for the 1/2 ton stuff, which happens to have a different dimension, and will not have leaf springs, so the question about the spring centers will not be based upon the spring perch since the 1/2 tons have no such spring perch.
I am looking through some of my old stuff to find the data to support this, but the D44 has several spindles that require very different outer stubs and have several diferent widths. Not all full size axles are the same width.
Old Jul 21, 2009 | 12:06 PM
ChaseTruck754
D'oh - that'll teach me to read ALL of the post.
Speaking of reading posts - I thought you WEREN'T gonna get sucked into FTE this morning
Old Jul 21, 2009 | 12:11 PM
75F350's Avatar
75F350
One more episode of Fall Guy!
Old Jul 21, 2009 | 03:13 PM
Brown Falcon
I actually want to run the coil spring suspension from the F150/Bronco and use the 8-lug hubs...
If that's the case would the Wheel Mount surface measurment still be 68"?
If so I just need a measurment from spring center to spring center on a coil sprung axle.
wyazel1
May 18, 2016 04:06 PM
balingwire
Feb 4, 2015 09:15 PM
'79 fourdoor
Nov 2, 2010 01:01 PM
dave75
Offroad & 4x4
24
Sep 25, 2008 01:29 PM
amcv8jeep
Oct 5, 2007 07:09 AM
