Valve clearance adjustment
Old Jul 20, 2009 | 10:00 AM
murph77's Avatar
murph77
I want to use a more accurate method of positioning individual pistons at TDC.
I'm afraid that marking the crank pulley every 120* won't be accurate enough.
I'm wondering if the marks shown below are, in fact, 120* away from the marks used for cylinders 1&6.
They seem to indicate TDC for cylinders 5&2. Right?
If so, is there a trick, or another mark for verifying TDC on 3&4?
300, I6.
Thanks for tips or advice,
Murph.
Old Jul 20, 2009 | 10:42 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
If you're real **** about it, just go off of the distributor. Roatate engine to TDC #1, adjust valve, rotate engine to line up rotor to 5 then 3, then 6, then 2, and finish on 4.
Your done.
Josh
Old Jul 20, 2009 | 09:03 PM
murph77's Avatar
murph77
I just finished adjusting my valves.
The part I wanted to share is how I measured the 120* between TDC of each cylinder.
I was turning the engine over with a breaker bar on the crank bolt... a hex bolt.
Measuring the placement of the wrench for each turn was the key.
Two turns of the hex bolt = 120*. It turned out to be very accurate.
Since there was only one reply, I thought I'd reply myself.
Hope this helps the next guy.
Murph.
52runner
13
Mar 22, 2015 10:01 PM
jstephens2
15
Nov 25, 2014 06:00 PM
abyars111
Oct 4, 2014 06:57 PM
Frank1721
1997 - 2003 F150
Sep 25, 2014 08:14 AM
Tedster9
13
Apr 7, 2014 10:42 PM
