Is there an aftermarket company that sells the bowl that the head light mounts to? Also, how bout all the screws that hold the light and are used for ajusting the light? All the plastic inserts on my grill are worn or missing. Thanks
If you need a headlight bucket send me a PM or e-mail, i have some extras, as far as the screws and plastic inserts for the adjustment, try your local parts house they should have them, i found mine at pepboys
a possible place to get the plastic nuts/retainers and their screws could also be from a wrecked car or truck...if its got an aluminum grille you can just tear out the part with the screws and plastic/nylon nut in it.
To clarify...a wrecked car/truck isnt just a car in the wrecking yard...a car/truck thats been hit up front hard....thus ruining the grill.
- cs65
Reason: clarification
Is there an aftermarket company that sells the bowl bucket that the head light mounts to? Also, how bout all the screws that hold the light and are used for ajusting the light? All the plastic inserts on my grill are worn or missing. Thanks
WHITE FORD MOTOR CO. in Chiefland FL has ONE = 800-777-4297.
GREEN SALES CO. in Cincinnati OH has ONE = 800-543-4959.
----------------------------------------------------------- C2TZ13181A .. Headlamp Plastic Adjusting Nut (does not include the screw) / Obsolete
PARTS INTERNATIONAL in Farmers Branch TX has 50 = 888-727-0418.
GREEN SALES CO. has NINE.
You can buy these at autoparts stores, but take a sample with you. There a gazillion different types!
------------------------------------------------------------------------------------------------ D1OZ13032A .. Headlamp Adjusting Screw (does not include the nut) / D1OZ13032A replaced C2OZ13032A / Obsolete
