removing emissions
Old Jul 28, 2009 | 08:44 PM
Franklin2's Avatar
Franklin2
Originally Posted by PerfDistIgnition
Point style ignition systems require you to run a ballast resistor to prevent from burning up your points. This reduces the voltage flowing through your ignition system to approximatley 9 or 10 volts, compared to the 14+ volts you can run through a Duraspark system.
http://www.performancedistributors.c...stributors.htm
This is not correct. The factory duraspark II system does require a ballast resistor, and all factory duraspark II vehicles have one in the wiring harness.
Old Jul 28, 2009 | 10:33 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Franklin is absolutely correct.
The Duraspark system requires a 1.05 to 1.15 Ohm ballast resistor in the run circut, powering the module and the coil. Reduces the voltage to around 8 volts DC. Only time the Duraspark module or the coil gets full voltage from the battery is when the truck is started. There is a ballast resistor bypass in the start circut going to the coil and module.
Old Jul 29, 2009 | 12:33 AM
hittman1422's Avatar
hittman1422
Since it's a 85 six, I bet it has the computer and everything.
thats what mine is but i dont have oxigen sensors, so therefore i have no feedback carb?
Old Jul 29, 2009 | 02:20 PM
Franklin2's Avatar
Franklin2
They could have taken them out and plugged the holes, or an older type exhaust manifold could have been installed. If you still have the sticker on the radiator, and you see EECIV on it somewhere, then it was a full computer controlled engine at one time. No vacuum advance on the dist is another clue.
Old Jul 30, 2009 | 12:46 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
Caught me!! You're right. I must have been thinking "the 14 volts you can run through a DUI ignition system."
My apologies.
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Old Jul 30, 2009 | 04:35 PM
Franklin2's Avatar
Franklin2
My apologies.
You guys use the GM HEI module in the dist correct? That's a pretty good system and does not require a resistor.
Old Jul 31, 2009 | 12:20 PM
PerfDistIgnition
FTE Sponsor
Yes, we use an HEI style module called the Dyna-Mod in our DUI Distributors. The Dyna-Mod has more dwell time set into it compared to the stock GM HEI module. The additional dwell time allows the coil to saturate longer, building up a more intense spark(kind of like switching from single to dual points in the older ignitions).
__________________
FTE Sponsor
cfrives3
Feb 7, 2024 10:59 PM
Andy Sullivan
15
Aug 5, 2014 08:35 AM
Ryan Hankins
Aug 17, 2013 07:59 PM
JB-1
71
Jun 23, 2012 09:32 PM
randrford
Aug 21, 2011 08:46 AM
