emissions removal
Old Aug 11, 2011 | 07:26 PM
randrford's Avatar
randrford
emissions removal
I have a 79 F100. Modified inline 6 300 to OFFY intake w/ Holley 4 Barrel and hedman hedders. My question is Ive removed all emissions equipment so Im assuming I dont need to replace the fuel vapor emissions line when I replace the fuel lines ? Sounds like a dumb question butr wasnt sure if that should be used somehow ???
Old Aug 11, 2011 | 07:38 PM
HIO Silver's Avatar
HIO Silver
The fuel vapor lines connect to a charcoal canister and connects to the intake stream either by way of the carb or an intake fitting. You'll need to install a breather unless the fuel cap is vented. If ya simply plug the line, the volumr og fuel used in running the engine will not be displaced by air thus creating negative pressure in the gas tank which, in turn, will cause fuel not to flow.
Btw, keeping the PCV valve is a good thing for street engines.
Old Aug 20, 2011 | 10:30 AM
amodel55's Avatar
amodel55
Hey Guys,
Ive taken all the emissions off my 1977 351M. Anything I should leave hooked up on this engine? Thanks/Robert
Old Aug 21, 2011 | 01:25 AM
fmc400's Avatar
fmc400
MSEE
Originally Posted by amodel55
Hey Guys,
You should not remove the EGR system.
Old Aug 21, 2011 | 08:46 AM
fasthauler's Avatar
fasthauler
I personally would leave the fuel vapor canister connected. It doesn’t have any effect on engine performance and, except for the added junk appearance under the hood, helps keep you vapors under control. Cars would have the leaking gasoline smells, especially on hot days, before they started installing these canisters. So, if you don’t like the smell of gasoline permeating from your vehicle I would kept it on. The EGR is another matter because it does affect engine performance.
moroza
Sep 4, 2018 02:25 PM
D. DeBoer
Dec 17, 2004 12:32 PM
cjben
Apr 10, 2003 09:35 PM
skips69
Mar 27, 2003 07:07 AM
Xwarrior86
Feb 25, 2003 02:59 PM
