central hydraulics
Old Jul 19, 2009 | 05:49 PM
dbf74's Avatar
dbf74
central hydraulics
I have a 96 f350 powerstroke. I recently got a 92 with a 7.3L with central hydraulics, and i want to put on the 96. It looks like the best thing to do is remove the dummy pulley where the a/c would go. I think it can be done with a flat plate to mount it on, as the pump is foot mounted. Anyone have any experience with this?
Old Jul 19, 2009 | 08:15 PM
tjbeggs's Avatar
tjbeggs
By central hydraulics I assume you mean hydraulics for like winches and hydra cylinders? Is it run off the belt of the 92? If so I would say there should be no problem with that. The only issue I can think of is 92's are v-belt and the 95 is an 8 rib serpentine belt. you will have to change the pulley on the pump.
Old Jul 19, 2009 | 08:25 PM
dbf74's Avatar
dbf74
Yes it does run off of the belt. And the pulley difference was the only thing I could see being an issue.
Old Jul 20, 2009 | 06:19 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Sounds interesting.
Have any pics?
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Jul 20, 2009 | 11:50 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
Be carefull of belt rotation. I assume the pump could only rotate in one direction to work. Even if it is placed in the same location as the 92, if the serpentine belt loops over the pulley on the wrong side it would cause it to rotate backwords. An example is water pumpes for 5.0L engines, the pump rotation is different between v belt and serpentine.
Old Jul 20, 2009 | 08:15 PM
joe_13894's Avatar
joe_13894
Only the water pump and the vacuum pump run with reverse rotation.
The A/C runs the same direction regardless of V-belt or serpentine.
stand-al0ne
WTB - Parts & other
Apr 25, 2016 12:36 PM
tvnoober
Jan 23, 2016 09:29 PM
Ziob
Nov 2, 2015 07:12 AM
crazyredneckanyhow
WTB - Parts & other
Mar 2, 2012 08:05 PM
Elwood72
Apr 9, 2011 08:21 PM
