Close Ratio C6
Old Oct 5, 2000 | 06:14 AM
William's Avatar
William
Close Ratio C6
I want to find or build a close ratio C6 for my 66 F100 with a FE390. Truck will be used for commuting and driving around on weekends. No hauling or towing. The close ratio in first and second should provide quick acceleration in traffic and the 1 to 1 in third coupled with a 3.0 rear ratio and 265/75 R 15 inch tires should provide about 2500 rpm at 70 mph. I need advice on torque converter specifications and sources. And I am soliciting expertise and opinion from anyone on this forum.
William in Atlanta
Old Oct 5, 2000 | 07:24 AM
DeenHylton's Avatar
DeenHylton
Close Ratio C6
>my 66 F100 with a
>rpm at 70 mph.
>this forum.
>William in Atlanta
William, what you probably really want is a "wide ratio" C-6 if I'm reading your post right. The wide ratios offer better (faster) acceleration in first and second gear but retain an "economy" 1:1 ratio in high. As far as I know all C-6s are close ratio. Ford installed the wide ratio gear sets in the E4OD auto trannys. You can purchase that gear set from Ford or a SVO Ford Motorsports Dealer. It will run you around $400 for the kit and will fit in a C-6. As far as tourque converters are concerned it will depend on how much modifications have been done to your engine, truck weight, gear ratio, intended use, etc. Deen
Old Oct 7, 2000 | 07:44 AM
billyb's Avatar
billyb
Close Ratio C6
Panhead55
Aug 22, 2015 09:04 PM
banjopicker66
Jan 20, 2010 12:51 AM
Ken Blythen
Sep 20, 2008 10:07 PM
1978Crew
Sep 3, 2004 01:16 AM
