1966 Fan Shroud
Old 08-22-2015, 04:47 PM
Panhead55
Panhead55 is offline
Panhead55 is starting off with a positive reputation.
1966 Fan Shroud
Hi Everyone,
I am a new member. I would like to put a fan shroud on my 1966 Ford truck. From the posts I've read (2010), it's possible provided everything matches up. The radiator and fan are stock and I have an aftermarket a/c kit. Looks like part # D3TZ-8146-C would work. My radiator bolt pattern measures 29 3/4" across by 11" tall, (overall radiator reads: 28' by 25"). The specs for shroud D3TZ-8146-C read: 28 1/4 by 22 1/4. Will this still work or is there another option?
Any help is much appreciated.
Thank you,
William
Old 08-22-2015, 04:57 PM
jowilker's Avatar
jowilker
jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
William the 8146 is key because the prefix changed along the way but 8TA is a part of it as well. Can't advise much past but you can make it fit.
John
Old 08-22-2015, 08:28 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
D3TZ-8146-C (replaced C8TZ-8146-K) .. Fan Shroud-Marked on upper left corner C8TA-8146-S or D3TA-8146-DA / Reproduced by Carpenter.
Original applications: 1968/76 F100/350 360/390 except with Super Cooling radiator.
This shroud will also work on 1965/66 F100/350's without modifications.
Old 08-22-2015, 09:04 PM
gangstakr's Avatar
gangstakr
gangstakr is online now
gangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud of
To bad your not in So. Cal. Panhead, I'd let you grab from the ones I have. I know I have one or two that would fit.
ihcc104
08-21-2016 08:58 AM
Kountry Star
06-22-2016 08:57 AM
ktgovols
05-01-2016 02:16 PM
warren561
12-26-2015 11:27 AM
ceetwarrior
08-25-2005 07:26 PM
Quick Reply: 1966 Fan Shroud
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
