8 lug differences??
Old Jul 18, 2009 | 12:26 PM
dpt47z's Avatar
dpt47z
8 lug differences??
hey there everyone. in recently purchased a set of rims that came off a 05 excursion thinking that both its 8 lug and my 73 f250 8 lug would match right up. well this morning i tried to put them on and they didnt fit!! well it was a rookie mistake not to make sure that both 8 lug patterns would fit. i was under the impresion that the 8 lug only changed sizes between manufactuers.my question is how many different sizes of 8 lug bolt patterns are there among ford trucks?when did they change?and is there any type of adapter that can be used??or is that route worth taking??thanks
Old Jul 18, 2009 | 12:31 PM
grandmas77f150's Avatar
grandmas77f150
I believe they changed after 1997, for Ford at least. Before then all manufacturers 8 lugs were the same. I tried the same trick with my dads stock 8 lugs from an 99 SuperDuty.
I may be wrong on the dates, someone will be along shortly to clarify better.
Old Jul 18, 2009 | 12:35 PM
5.8LiterImportEater's Avatar
5.8LiterImportEater
On that new of a truck I suspect your problem is that ford switched to a metric lug spacing.
As far as I know up until the SD style that ford used the same lug pattern as Dodge did, but now they run metric.
I don't know the exact spacing in MM but I think it is something like 8x200mm. Sucks for sure.
As far an adapter there are a couple of sites apparently if you search google. But they are stupid old. I will search for some more
Those were the first ones I saw pop up.
Chris
Old Jul 18, 2009 | 12:49 PM
dpt47z's Avatar
dpt47z
yea i googled it and found the same thing....also found that the excursion runs the 8x170mm bolt pattern....i was just wondering if anyone else has run into this and if anyone has used an adapter??
Old Jul 18, 2009 | 03:50 PM
75F350's Avatar
75F350
Price adapters and then consider how far the offset will be changed, along with the added scrub radius and you will find less of a value in this idea.
Cheaper to just get the right wheel.
Old Jul 18, 2009 | 04:14 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Cheaper and safer in my opinion.
Old Jul 18, 2009 | 06:40 PM
ford390gashog's Avatar
ford390gashog
Ford went to 8x170mm in 99 model year. GM and Dodge still use the old 8x6.5'' pattern but the hub size on the GM is smaller and will not fit over the Dana 60 hub.
Old May 28, 2010 | 11:16 AM
73cntry's Avatar
73cntry
So basically a 17in rim from a chevy still wouldn't be big enough to fit over our DANA 60 hub. I always thought the hubs were the same size for floating rear ends anyways but guess the front axles may have different sizes. Never really thought of that.
Old May 28, 2010 | 11:46 AM
ChaseTruck754's Avatar
ChaseTruck754
Try a little searching on the topic. It's been covered LOTS of times and all sorts of info is out there. There is a very recent thread about a guy doing H2 wheels and fixing the hub fitment issue. I have gone over drill and sleeving the wheels before etc.
Old May 28, 2010 | 12:10 PM
breedo99's Avatar
breedo99
i almost ran into the same problem when i was gonna buy some wheels from a guy that had them on an 04 ford...luckily i asked on here first and saved myself 600 bucks(they were aftermarket wheels) the thread was titled 8 lug wheel questions i believe if you wanna look at it
glennemay
Massachusetts Chapter
Mar 31, 2012 01:54 PM
mejonz
Nov 3, 2011 03:30 AM
jeff1975
15
Sep 22, 2009 12:40 PM
Milwaukee1979F150
May 3, 2009 12:00 PM
steelers06steelers
May 11, 2008 09:45 AM
