ABS Light On after......
Old Jul 18, 2009 | 12:15 PM
jebdrup's Avatar
jebdrup
My ABS light came on after I replaced the alternator and battery...any ideas? I have no blow fuses and the charging system is working.
Back ground: 2002 Excursion V10 4x4 Limited w/112,000 miles
4 days ago after pulling in the drive way and shutting it off it would not start. It made a clicking noise and the tac and speedo needles went all the way over. I tested the battery and it was at 12.5 volts. I spoke with my father (retired mechanic) and he said it sounded like a bad battery. The battery was 4 years old so I replaced it with a new one. I did not test to see if the alternator was bad...we had just got back from a road trip from Florida to Texas (it has been over 100 degrees for a week).
Last night it did the same thing and test the battery and alternator. The alternator was bad (Autozone and Fluke tested) and the battery was at 8.5 volts. I had the battery warrantied and I got a new alternator.
This morning I put both the alternator on and the battery in and fired it up. The ABS light came on and will not go off.
When I put the key in the on position the light goes off until the pump under the hood makes a noise then the light comes on.
Any help.
Thanks,
Jeremy
Old Jul 18, 2009 | 05:06 PM
jebdrup's Avatar
jebdrup
I took the Excursion out for a test drive and the light went off. Ran for an hour and no issues.
Old Sep 23, 2009 | 11:10 PM
landk00's Avatar
landk00
No dash lights to indicate alternator problem???
Did your battery light come on? I also have a 2002 EX and autozone is telling me the alternator is bad; however, I have no battery light while engine is running. The battery was replaced last month. Any feedback would be greatly appreciated.
Shutech
Apr 21, 2015 09:31 PM
Calheader
Nov 19, 2014 02:30 PM
greg_8507
Jan 20, 2014 03:43 PM
cree92831
18
Oct 9, 2013 03:14 PM
acf6
Apr 11, 2012 07:30 PM
